Thread: ImageMagick
    Sep 2004
    Peoria, AZ
    250
    Default ImageMagick
    Hey does anyone know how I can find the path to the ImageMagick 6 binaries (convert and identify)?
    I used the example, however, they are not there.
    Your help is appreciated!
    May 2004
    Tempe, Arizona
    1,938
    Default Re: ImageMagick
    /usr/bin/ is what I am using
    Sep 2004
    Peoria, AZ
    250
    Ya it does not seem to be there??
    Feb 2004
    Belgium
    18
    Quote Originally Posted by xtremeoff-road
    if you have ssh access you can type
    which convert
    which identify
    that should return the absolute path to both programs usually it's something like "/usr/local/bin/"
    ciao
    On most servers it would be /usr/bin/ or usr/local/bin/. If neither of those work then your host should be able to tell you the correct path.
    Sep 2004
    Peoria, AZ
    250
    WOOHOO ok finally got it...first problem is an issue with the installation. Guess the control panel did not install it correctly. Second, the path is completely different than what would be normally used.
    All in all, it is working
    Thanks for the replies!
