Page 2 of 11 FirstFirst 12345 ... LastLast
Results 21 to 40 of 213
Thread: Advanced Navigation module for vBulletin 3.5.x and CMPS 2.0
  1. #21
    Sep 2005
    Default Re: Advanced Navigation module for vBulletin 3.5.x and CMPS 2.0
    Got it working; Man this is a Good Hack: This is useful: Made a change to it: Check it out: www.wealthbrokers.org
  2. #22
    May 2005
    installed. thanks!
  3. #23
    Syracuse, NY
    170
    installed here as well!! Thanks
  4. #24
    Maryland
    115
    Got in contact with 58sniper (Thank you sir!)in regards to adding his 1.X module Super Search 2 (read more) and said it would be fine to share it with other useres here.
    This adds like 9 more search engines to your module.
    Replace in your nav template..
    <!-- Search -->
    <hr size="1"/>
    <form action="{$vbulletin->options[bburl]}/search.php" method="post" name="search"> <input name="s" type="hidden" value="" /> <input name="do" type="hidden" value="process" /> <input name="sortby" type="hidden" value="lastpost" /> <input name="forumchoice" type="hidden" value="0" />
        <input class="bginput" name="query" size="16" type="text" /> $gobutton
        <div class="smallfont">&raquo; <a href="$vboptions[bburl]/search.php?">$vbphrase[advanced_search]</a></div>
    </form>
    <!-- / Search -->
    With this here..
    <!-- Search -->
    <hr size="1"/>
    <script type="text/javascript" language="JavaScript">
        function startSearch(){
         searchString = document.searchForm.searchText.value;
         switch (document.searchForm.whichEngine.value) {
         case "altavista":
         finalSearchString = "http://www.altavista.com/web/results?q=" + searchString;
         break
         case "yahoo":
         finalSearchString = "http://search.yahoo.com/search?p=" + searchString;
         break
         case "excite":
         finalSearchString = "http://msxml.excite.com/info.xcite/search/web/" + searchString;
         break
         case "hotbot":
         finalSearchString = "http://www.hotbot.com/?MT=" + searchString;
         break
         case "infoseek":
         finalSearchString = "http://www.infoseek.com/Titles?qt=" + searchString;
         break
         case "lycos":
         finalSearchString = "http://www.lycos.com/cgi-bin/pursuit?query=" + searchString;
         break
         case "aolnetfind":
         finalSearchString = "http://netfind.aol.com/aolcom/search?query=" + searchString;
         break
         case "google":
         finalSearchString = "http://www.google.com/search?q=" + searchString;
         break
         case "mysearch":
         finalSearchString = "http://mysearch.myway.com/jsp/GGmain.jsp?searchfor=" + searchString;
         break
         case "netscape":
         finalSearchString = "http://search.netscape.com/ns/search?query=" + searchString;
         break
         case "vb":
         finalSearchString = "";
         document.searchForm.action = "$vboptions[bburl]/search.php";
         document.searchForm.method = "post";
         document.searchForm.query.value = document.searchForm.searchText.value;
         document.searchForm.submit();
         return true;
         break
         default:
         document.location = finalSearchString;
         return true;
    </script>
    <form name="searchForm" method="post" action="">
        Search for: <input name="searchText" type="text" size="17"/> <b>@</b>
        <input type="hidden" name="do" value="process" />
        <input type="hidden" name="showposts" value="0" />
        <input type="hidden" name="query" />
        <select name="whichEngine">
         <option value="vb">$vboptions[bbtitle]</option>
         <option value="altavista">Altavista</option>
         <option value="yahoo">Yahoo!</option>
         <option value="excite">Excite</option>
         <option value="hotbot">Hotbot</option>
         <option value="infoseek">Infoseek</option>
         <option value="lycos">Lycos</option>
         <option value="aolnetfind">AOL Netfind</option>
         <option value="google">Google</option>
         <option value="mysearch">MySearch</option>
        </select>
        <center><input type="button" value="Search" onclick="startSearch();" /></center>
    </form>
    <!-- / Search -->
  5. #25
    Oct 2005
    20
    amazing great work on the mod....
  6. #26
    Oct 2005
    18
    I need a help guys.. When i click on Go (for search) i want the search to open in a new window.. If the user is gonna search in google i do not want him to go outside my site.. But i want that search engine option.. Can someone tell me how to open the search results in a new window?
  7. #27
    Nov 2005
    11
    So, how to modify the structure of the menu?
    I can not find place for modification in the control panel. Have to midfy the "adv_portal_navmenu" file manually?
  8. #28
    Dec 2004
    Holland
    33
    Quote Originally Posted by nengrong
    Correctly, you must adapt the template
    One Shared Passion
    DUTCH RACING LEAGUE
    BarfPK Racing
  9. #29
    Nov 2005
    11
    I do not have any experiance in PHP. I understand the structure of the code for popup menu. However, is there anybody who can tell me how to modify the code to include sub-link menu ? Where and how to add? An demonstration is great. Thank you very much.
    <!-- Items Menu -->
    div class="vbmenu_popup" id="items_menu" style="display:none;margin-left:100px;">
    table cellpadding="4" cellspacing="1" border="0">
    tr><td class="thead">Items Menu</td></tr>
    tr><td class="vbmenu_option"><a href="$vboptions[bburl]/index.php">linked item for your site</a></td></tr>
    table>
    div>
    Links menu -->
  10. #30
    Im going crazy here cuz I am not able to edit the menu module without it saying this is not a valid module every time I try to update it.
    How are you guys editing the menu? This is driving me nuts!
  11. #31
    Same problem I was having.
    Not sure as to the technical reason for this, but you can not edit the module directly and then upload it.
    Instead go to
    ADMINCP > Styles and Templates > Style Manager > Default Style (well for me anyway) >adv_portal_navmenu
    Then edit code in this file.
  12. #32
    I'm having trouble getting the background/rollover effects to display properly. Can anyone tell me what I need to change to make this work right? (See screenshot).
    When I roll over the links that are black, they then appear, the background around the links still remains black.
  13. #33
    The problem seems to be that the background always stops at that same spot no matter what other menu pieces I add or take away.
    The background is a .gif file. The default background COLOR (black) shows but the pic stops displaying at that spot. The only way I've found to fix it is to enclose each block in a <td><tr>.
    Any suggestions?
  14. #34
    Oct 2005
    20
    anyone ever think about making this html complaint?
  15. #35
    Thanks very much for this.....works great!!
  16. #36
    Sep 2005
    This is a great module. Thanks for you work!
  17. #37
    Nov 2005
    20
    Thanks for the share! Works great!
  18. #38
    Nov 2005
    This is really nice. Dumb question... How do I change the menu items? I don't see anything when I click on cmps/edit modules.
  19. #39
    Dec 2004
    Holland
    33
    Quote Originally Posted by joelc73
    Styles & Templates --> Style Manager --> in all style options choose edit templates and search for the adv_portal_navmenu template.
    One Shared Passion
    DUTCH RACING LEAGUE
    BarfPK Racing
  20. #40
    Nov 2005
    Quote Originally Posted by drl2005
    So I actually have to edit the code itself?
  1. New posts on Advanced CMPS
    By Basscat in forum Troubleshooting & Problems
    Last Post: 09-01-2005, 05:46 PM
  2. If you update from CMPS 1 and had a template/module called Navigation
    By Morwyn in forum Troubleshooting & Problems
    Last Post: 06-11-2005, 02:22 PM
  3. vBa CMPS: VBulletin Radio Module
    By brianstevz in forum Add-On Modules & Modifications
    Last Post: 05-09-2005, 02:07 PM
  4. Request: More advanced arcade module...
    By himerus in forum Add-On Modules & Modifications
    Last Post: 06-19-2004, 07:45 PM
  5. More Advanced News Module
    By bfoot045 in forum Feedback & Suggestions
    Last Post: 06-15-2004, 12:31 AM
