Results 1 to 20 of 33
Thread: [MODULE] Top 10 Posters
    Jul 2004
    26
    Default [MODULE] Top 10 Posters
    This module was originally created by Acido for vBA CMPS 1.x on 3.0.x, I just ported it over to CMPS 2.x on 3.5.x. The original module can be found here.
    File uploads - 1 (topten.php)
    New templates - 2 (adv_portal_topposters, top_posters)
    Download the zip file, follow the install instructions, and enjoy!
    28
    Default Re: [MODULE] Top 10 Posters
    Has a few bugs in it. Can't seem to move it over any where.
    Jul 2005
    edit problem fix
    Dec 2005
    followed everyone's advice but it doesn't work
    Dec 2005
    this is the error I get
    Fatal error: Call to a member function on a non-object in /usr/home/poin64/www/htdocs/cats/modules/topten.php on line 7
    can anyone help?
    Apr 2004
    Canoga Park, CA
    101
    Quote Originally Posted by pointguardu
    can anyone help?
    http://www.vbulletin.org/forum/showt...threadid=99069
    http://www.szone.us/ | http://www.gzhq.net/
    My:Hacks @ vBulletin.org
    Volunteer Support @ vBulletin.org
    Virginia Beach, VA, USA
    222
    Question, I reversed engineered this hack to display the 10 most recent registrations, then I changed the displayed amount to 3.
    Anyway I could then get it to display their avatar?
    Mike Key - Lost and Confused
    Nov 2005
    Messina
    23
    Excellent module Zachariah, installed...
    Quote Originally Posted by Brubaum
    yea I concur, I could not get the one is this thread to work for nothing even with custom editing but the one from zach was good the first time all the way through.
    Nov 2005
    cool thank
    Works great...
    but the title (row where you can collapse) is not the full width...
    Any suggestions?
    www.cannondalecentral.com (located on the right side of home and forum page)
    Thanks in advanced
    I also get this error message when I try to open a post...Module is located on the forum page
    Unable to add cookies, header already sent.
    File: /var/www/html/forum/modules/topten.php
    Line: 15
    Found out why....
    Remove from line 15 ?>
    the code I used
    <?php
    // ### TOP STATS ########################################
    $top_stats = array();
    // TOP POSTERS
    $top_posters = $db->query_read("SELECT * FROM ".TABLE_PREFIX."user ORDER BY posts DESC LIMIT 10");
    while($top_poster = $db->fetch_array($top_posters))
    eval('$top_stats[\'top_posters\'] .= "' . fetch_template('top_posters') . '";');
    unset($top_poster);
    $db->free_result($top_posters);
    eval('$home[$mods[\'modid\']][\'content\'] = "' . fetch_template('adv_portal_topposters') . '";');
    also replace the code in the top_posters template to...
    fixes the shift of the top of the mod
    <td class="thead"><span class="smallfont"><a href="/forums/member.php?u=$top_poster[userid]">$top_poster[username]</a></span>
    <class="$bgclass"><span class="smallfont"><strong><a> </a>[$top_poster[posts]]</strong></span></td>
    Jul 2005
    cdembek, could you please re-bundle this with your mods?
    Here you go....
    Dec 2005
    Talking Re: [MODULE] Top 10 Posters
    Quote Originally Posted by cdembek
    Here you go....
    Thx ist works,Fine!!
    Sorry for English,my Parents are German,and i`m too
    Nice one..Installed!
    9
    thanks for the job.
    thinking that it is too simple to lose some concerns, that is why there r problems.
    Apr 2006
    9
    how do i change the path so when they click on the screennames of one of the top 10 posters, it goes to their profile. Right now when i click on a screenname, it takes me to /forums/member.php. But it should take me to /tvsf/member.php. Thanks
  1. G180 Top Posters
    By Polo in forum Add-On Modules & Modifications
    Last Post: 07-19-2006, 04:46 PM
  2. REQ: Top 10 posters Module
    By MotoUp in forum Module & Modification Discussion & Requests
    Last Post: 10-23-2005, 04:56 AM
  3. Top (10) Posters Module
    By Acido in forum Add-On Modules & Modifications
    Last Post: 10-08-2005, 09:20 AM
  4. Module for Paul M's Top 10 Posters
    By dsboyce8624 in forum Add-On Modules & Modifications
    Last Post: 08-21-2005, 02:01 PM
  5. Mod for Top Posters per day average
    By deb0 in forum Add-On Modules & Modifications
    Last Post: 11-30-2004, 07:04 AM
