Page 3 of 31 FirstFirst 12345613 ... LastLast
Results 41 to 60 of 616
Thread: [Module] Customizable RSS feed module
  1. #41
    Default Re: [Module] Customizable RSS feed module
    I'll try this one...thanks.
    FYI, your sample code in the original post which shows how to include the date has an extra ')' at the end of the first line of code.
  2. #42
    Thanks - it's fixed now.
  3. #43
    That's working, though it was still a little cranky. I had to re-enter the URL of the feed in the first module for some reason, because both modules ended up showing the same feed. I'm going to try a third feed...we'll see how that goes!
    How hard would it be for a non-coder like me to have the feeds only show the headlines and date, with none of the actual article content?
  4. #44
    Okay...it didn't like three feeds. Two are working, but I wasn't able to add the third...
  5. #45
    D'oh. I had two working, but I tried to change the feed on the second one and broke the whole thing.
  6. #46
    Quote Originally Posted by euangel
    How did you create the multiple feeds? I've got 4 different feeds running correctly on my test page.
    I've run across a problem in CMPS when duplicating modules that causes things to "break" with the only way to resolve it to delete all the custom modules that experience a problem, including the original one, and starting the process over. I've also had to go into the db and manually delete records. I thought this was only related to when creating the module and options but apparently not. I've reported it and similar behavior as a problem.
    What I do now that seems to work is to import the module and leave it alone. I then make a copy of it and save it. Then I go back and edit that copy and leave the blank one alone. If you need a 2nd module repeat the copy process, making for a total of 3 versions (the original plus 2 copies). I currently have 5 copies of the RSS module, 4 of which are "real" and 1 is the original blank one.
  7. #47
    Apr 2005
    How do I prevent catagory from appearing? I think it's category anyway. I'm using a Google feed and apparently category is the same as the title and author so it's kind of redundant. I made changes to the rssbits template and it doesn't seem to be sticking...or I'm trying to change it in the wrong place.
    My site is here: http://indigovortex.com
  8. #48
    Apr 2005
    Nevermind, I got it. It was Google. I thought I could skip using Grouper since Google has rss news feeds, however Google adds html to their rss feed as well as repeating the title in the item description.
  9. #49
    If the HTML is consistent it's possible to use the Data Modification code section for the feed to strip it out (unless the feed TOS says you can't do this). This removes the category
    $rss_item['CATEGORY'] = '';
    w/o having to esdit the adv_portal_rssbits template.
    This shortens long descriptions and adds a '... [Read More]' that will open in a new window
    substr($rss_item['DESCRIPTION'], 0, strrpos(substr($rss_item['DESCRIPTION'], 0, 200), ' ')) . '... [<a href="' . $rss_item['LINK'] . '" target="_blank">Read More]';
    The possibilities are pretty endless as to what you can do w/o having to edit the templates.
  10. #50
    Thanks Tom...I'll give that a try. Does deleting the module remove the info in the database, or am I going to need to go it to the database to do that?
    I'm also considering showing a full entry rather than just the description. What would the code be for that?
  11. #51
    In my case I needed to do some manual deletion but that was on my development db. Deleting the module is supposed to delete all the stuff related to it, except for the php file and the templates. However if you have multiple copies of the module it doesn't currently seem to do that - which is where one of the problem seems to be. After deleting all the copies of the module I had to go in and manually take car of stuff. You can see what tables are used by looking in the vBa admincp app in the doremovemodule section.
    Not sure what you mean here. The description that shows by default is the full description that's in the feed unless it's modified by the Data Modification code. You can always look directly at the cached version of the feed to see what's in it
  12. #52
    Dec 2005
    Quick question.
    First, love the hack.
    Now, if I want this on more than one template (users have the option to change from three different ones) I'm assuming I just re-upload the rssfeed.module, and set it for another template??
    Here.
    www.jake25.com (it's defaulted to "classic" style) and I want to set it up for the silver/red 2 black.
    Cheers, Jake
  13. #53
    Actually, it's no different than any other module. However you have the others set up to show in all styles then that's what needs to be done with this. The only reason to copy the basic module is if you want an additional rss feed displayed.
  14. #54
    Dec 2005
    Hmm, not sure how to do that. Upon installation, it asks what template you want it installed on.
    If I knew what parts of the "classic" template was changed, I'd just copy over to the other two. Any ideas?
    I'm thinking the only way to do that, would be to re-install the module, and when it asks what template I want it displayed on, to choice one of the others.
    EDIT...
    Never mind. Put one as parent, and whichever will follow.
  15. #55
    thanks works like a charm.
    however from reading it seems that you should put how to add additional modules in first post.
    but dumb it down a little
    Fighting For Peace, Is Like Screwing For Virginity
  16. #56
    Dec 2005
    9
    Is there any way to make it scroll the news articles or does it have to be in a list?
  17. #57
    Quote Originally Posted by Thiefer
    It's currently designed to be a list. You could always edit the adv_portal_rss template, place the list portion in a fixed height <div> and let that scroll by using overflow:auto.
    Perhaps I'll make that an option in a future release.
  18. #58
    Dec 2005
    9
    You think you could give me a little more of n example. I do not see where it states the list in that template. So I am unable to force its size
  19. #59
    What I did as a quick'n dirty test was add the bit in red
      <td>
        <div style="height: 400px; overflow: auto;">
          <table width="100%" cellspacing="0" cellpadding="5">
    		$rssbits
    It works but messes with the table cell widths a bit so it would need some tweaking. It should get you started though.
  20. #60
    Dec 2005
    9
    where would I put the overflow:auto? Sorry I just have never done this before
    Edit, I can't get this to work at all. Everytime I change something it breaks everything.
  1. Webcam Feed Module
    By SVTOA in forum Add-On Modules & Modifications
    Last Post: 06-11-2006, 01:14 PM
  2. vBa CMPS: Customizable RSS feed module
    By Tom M in forum Add-On Modules & Modifications
    Last Post: 05-30-2006, 12:31 AM
  3. RSS feed module for VBA 2 and VB3.5
    By rsailors in forum Modifications (version 3.x & 2.x)
    Last Post: 03-25-2006, 10:18 PM
  4. [REQ] RSS feed module
    By rgourley in forum Module & Modification Discussion & Requests
    Last Post: 10-21-2005, 11:55 PM
