Page 31 of 31 FirstFirst ... 2128293031
Results 601 to 616 of 616
Thread: [Module] Customizable RSS feed module
  1. #601
    Jul 2008
    19
    Quote Originally Posted by mickknutson View Post
    I do not understand what to do here.
    I have custom styles, I also see the styles when I import the module. But I still do not get anything showing.
    * Yes the module is active.
    * Yes it is set to display on the center of my page
    * Yes the cache is created and has data in it >0K
    * I even tried the CURL version and no display either.
    * I uninstalled several times to try this.
    * I tried several different feed URL's and they all did as above, but never displayed.
    And still no display http://www.blincmagazine.com/cmps_index.php
    This is the thread for the old version of this module, if you have vB 3.7 - you need to upgrade you module...the old module doesn't work in 3.7.
    here's the link to the new thread:
    http://www.vbadvanced.com/forum/showthread.php?t=24401
  2. #602
    Jul 2009
    hey I need some help. what I'm attempting to do is disable and/or set maximum dimensions for images being brought in through feeds. i know how to do this with css but i need to know the element names like .rssdesc listed in the first post.
    thanks in advance.
  3. #603
    Quote Originally Posted by AccioNaveed View Post
    thanks in advance.
    Are you using the OLD version (this thread) or a current version of vBulletin? If the latter then please post in the correct thread... new thread.
  4. #604
    keep getting this message
    Warning: file_put_contents(home/fordtruc/public_html/cache/media.ford.com-rss.xml.cache) [function.file-put-contents]: failed to open stream: No such file or directory in /modules/rss_cmps2.php on line 222
  5. #605
    Quote Originally Posted by slmann View Post
    What version of vB are you using? If it's a newer version then you will need to use the newest version of this module (check a few posts up for more info).
  6. #606
    Quote Originally Posted by Tom M View Post
    vb 3.6.4
  7. #607
    You should switch to the version meant for 3.6.x. It can be found right here.
  8. #608
    tried to upload the correct one but when I do it doesn't work correctly. On my edit module page it adds "move to" and directional arrows but on title, so you can't click on it to edit it
  9. #609
    Are you saying the "Move to" isn't a drop-down box? If so then that's a vba problem and not related to the module.
  10. #610
    what I'm saying is that when I upload the file it only puts in the "move to" and no module title. With no module title there is nothing to click on so you can edit the module
  11. #611
    If there are no errors when loading the module (assuming it's the right one for the version of vBa you are using) then it would seem to be a vBa problem. Regardless, it's certainly strange.
  12. #612
    Feb 2009
    Can somebody assist me at pulling attachments from my rss feed? I was able to do it on WordPress but can't figure it out here. Thanks.
  13. #613
    Quote Originally Posted by MikesSite View Post
    You will need to provide a bit more information, like a site link, feed url, and what it is you really want to do.
  14. #614
    Feb 2009
    Thanks for your response.
    The feed url is: http://feeds.feedburner.com/SocialFeeds
    The site url is (shortened): http://goo.gl/xbnKP You can see in the middle of the center column where it says "Social Feed"
    Thanks.
  15. #615
    Aug 2009
    can access the file directly without curl. Curl is very slow
    example
    if(!function_exists('rss_get_contents'))
    function rss_get_contents($file)
    if (strncmp('/home/folder/wp-rss.php' , 5) != 0) No URL; local file same server
  16. #616
    Mar 2006
    The Netherlands
    Hello everybody,
    I'm looking for some support. I use this RSS module on my board and i want to change the layout of the rss feed, Currently this is what i see:
    Wat i want is something like this:
    I like to have everything displayed in one line.. first the date, and then the subject..
    Can some give me advise what to do... Where to look...
    With very kind regards,
    Robert Waanders
    Modelbouwforum.nl
  1. Webcam Feed Module
    By SVTOA in forum Add-On Modules & Modifications
    Last Post: 06-11-2006, 02:14 PM
  2. vBa CMPS: Customizable RSS feed module
    By Tom M in forum Add-On Modules & Modifications
    Last Post: 05-30-2006, 01:31 AM
  3. RSS feed module for VBA 2 and VB3.5
    By rsailors in forum Modifications (version 3.x & 2.x)
    Last Post: 03-25-2006, 11:18 PM
  4. [REQ] RSS feed module
    By rgourley in forum Module & Modification Discussion & Requests
    Last Post: 10-22-2005, 12:55 AM
