Page 4 of 31 FirstFirst 123456714 ... LastLast
Results 61 to 80 of 616
Thread: [Module] Customizable RSS feed module
  1. #61
    Default Re: [Module] Customizable RSS feed module
    Quote Originally Posted by Thiefer
    where would I put the overflow:auto? Sorry I just have never done this before
    If you cut/paste the bit in red that I posted into the adv_portal_rss template it will add a scrollbar. From there you can begin to modify things to try it out.
  2. #62
    thanks for the wonderful add-on! The update corrects all the weird problem 1.0 only showing feeds randomly . This one is so clean too
    thanks!
  3. #63
    Dec 2005
    9
    It did everyting nicely but it still will not scroll automatically
    This is the code I have
    <div style="height: 300px; overflow:auto;">
          <table width="100%" cellspacing="0" cellpadding="5"><tr><td>
    <table align="center" border="0" cellpadding="$stylevar[cellpadding]" cellspacing="$stylevar[cellspacing]" class="tborder" width="100%">
            <td class="tcat">
              <span class="smallfont"><strong>$vba_options[portal_blockbullet] <a href="$rss_channel[LINK]">$rss_channel[TITLE]</a></strong>
              </span>
    $rssbits
    <if condition="$rss_channel[COPYRIGHT]">
            <td class="tfoot" align="center">
                <span class="smallfont"><a href="$rss_channel[LINK]">$rss_channel[COPYRIGHT]</a></span>
    </if>
  4. #64
    The <div> needs to be like I showed in my example as you only want the bit inside the module (the actual feed data) to scroll.
  5. #65
    Dec 2005
    9
    With the code how it is it is setup correctly without auto scrolling
    see take a look at my site
  6. #66
    An updated version of this module has been placed in the first post.
    1/4/2006
    1. Added support for having the feed area scrollable. This adds two new options to the module and also contains a revised adv_portal_rss template.
    If you don't require scrollable support there's no need to download this update.
  7. #67
    Dec 2005
    9
    I still can't get it to auto scroll, but oh well.
  8. #68
    You *may* need to uninstall all earlier versions and manually delete some table entries to get the update to work properly. I'm still waiting to hear back if Brian has been able to reproduce the problem I've seen.
    In the meantime, I'll be happy to take a look at things for you if you'd like. PM me if you'd like help in doing this.
  9. #69
    Jul 2005
    11
    I just added this modules, but nothing happens.
    No error message, nothing.
    I last used lastRSS with fsockopen - fopen doesn' t work at my server.
    Could this be the problem?
  10. #70
    Quote Originally Posted by archimedes
    What is the url of the feed you are trying to use?
    Is the module marked as Active?
    If the fopen() failed you should get an error message.
  11. #71
    Jul 2005
    11
    I tried www.fscklog.com/atom.xml and the external.php?type=rss2 of my forums.
  12. #72
    The layout of that feed doesn't match what the applications is looking for and so the content gets bypassed.
    The app is looking for a format like
    <content>
    <items>
      <item>
         item related stuff
      </item>
      <item>
        next item related stuff
      </item>
    </items>
    </channel>
    You could probably modifiy the php file to process the format that being looked at w/o too much trouble and save it as a different version.
  13. #73
    Jul 2005
    11
    Take a look at http://www.heise.de/newsticker/heise.rdf
    this feed also doesn't work...
  14. #74
    If you examine the feed you'll see that it also doesn't meet the requirements.
    You can read about file formats here and here.
    Basically, the application supports the RSS 2.* branch and not the RSS 1.* formats.
  15. #75
    Jul 2005
    11
    Can you give me a feed to test if the feeder works?
  16. #76
    The sample files referred to on this page all work for me.
  17. #77
    Mar 2005
    9
    I just did a new install of vb3.5 along with cmps2.0. Everything installs fine, but I can't get anything on the frontpage. I am using the following URLs from your recommendation: My directory is chmod to 777. Any ideas?
    http://liftoff.msfc.nasa.gov
    http://rss.cnn.com/rss/cnn_topstories.rss
  18. #78
    Not much to go on here. The first link points to a web page that says the site is no longer supported and the 2nd one comes up fine for me.
    Have you made sure that the module is marked as Active and that it's selected on the page you are using?
  19. #79
    Mar 2005
    9
    Tom,
    Thanks for the reply. I have checked that the module is listed as active, and have even chmod' my directories to 777.
    Here are my specs:
    /home/affna/org/html/rsscache
    All active boxes are checked
    I've even tried uninstalling/reinstalling the module. Anymore ideas? Thanks again for your help/hardwork.
    Val
  20. #80
    Maryland
    115
    Ok this is all very new to me.
    I have uploaded the the feeds.moduel via admincp > CMPS
    I get this here:
    Fatal error: file_put_contents cannot write in file. in /modules/rss_cmps2.php on line 125
    What does it mean?
  1. Webcam Feed Module
    By SVTOA in forum Add-On Modules & Modifications
    Last Post: 06-11-2006, 01:14 PM
  2. vBa CMPS: Customizable RSS feed module
    By Tom M in forum Add-On Modules & Modifications
    Last Post: 05-30-2006, 12:31 AM
  3. RSS feed module for VBA 2 and VB3.5
    By rsailors in forum Modifications (version 3.x & 2.x)
    Last Post: 03-25-2006, 10:18 PM
  4. [REQ] RSS feed module
    By rgourley in forum Module & Modification Discussion & Requests
    Last Post: 10-21-2005, 11:55 PM
