Thread: currentpoll.php dateline problem - only 0 in date cutoff works for some users?
    Feb 2004
    15
    Arrow currentpoll.php dateline problem - only 0 in date cutoff works for some users?
    Hey,
    I could not find this bug, I'd be very surprised if no one posted this before me as it almost makes the poll unusable.
    Many members (though not every one - i can't reproduce it myself i can only reproduce it on others who have the issue)) gets the following problem:
    If the dateline is set to anything other than 0 (30 days, 60 days, 90 days, etc...) they get this error when attempting to view the portal:
                SELECT thread.pollidopenthreadidreplycountforumidquestionpoll.datelineoptionsvotesactivenumberoptionstimeoutmultiplevoters, public , voteoption
                FROM poll
    AS poll
                INNER JOIN thread
    AS thread USING (pollid)
    LEFT JOIN pollvote AS pollvote ON (pollvote.pollid poll.pollid AND pollvote.userid 20101)
    WHERE open <> 10 AND visible AND active 1
    AND thread.dateline 1131382802AND thread.postuserid NOT IN(2302,22171)
                AND
    thread.forumid NOT IN(8,25,36,18,19)
    ORDER BY poll.dateline DESC
    I have changed every single option in there to isolate what was causing it (changing to random instead of date created and played with EVERY other option in that section), and everything works when I set date cutoff to 0 but NEVER when it's moved to 30, 60, 90, etc. That's the common factor in making the page not work for those users. Perhaps its not working because currentpoll.php sticks the dateline right up against the word "AND" which is not correct right? As in the error above, AND should be seperate no? Did I find something?
    Help!
    Default Re: currentpoll.php dateline problem - only 0 in date cutoff works for some users?
    Looks like a small problem with the dateline limit when a user has members on their ignore list, or you have some tachy'd users. If you'll look in your modules/currentpoll.php file for this code:
    iif($ignusers'AND thread.postuserid NOT IN(' $ignusers ')') .
    iif($ignusers' AND thread.postuserid NOT IN(' $ignusers ')') .
    Then that should take care of the problem. The download package here has also been updated to add this change.
    Feb 2004
    15
    Thank you SO much as always for your tireless efforts, Brian!
    I'll give that a shot this evening!
  1. Fill dateline manually in MySQL?
    By blikos in forum "How Do I..." Questions
    Last Post: 10-22-2005, 09:30 PM
  2. Using currentpoll module on another page
    By sully02 in forum Troubleshooting / "How do I..." Questions
    Last Post: 12-10-2004, 07:41 PM
  3. currentpoll.php problem
    By Axel Foley in forum Bugs & Other Issues
    Last Post: 09-10-2004, 01:48 AM
