Results 1 to 19 of 19
Thread: [Hack] Collapse Left Sidebar of vBA CMS (1.0.0)
    Smile Collapse Sidebars of vBA CMS (1.0.1)
    Version: 1.0.1
    vB Version: 3.5.2
    Assuming that you have vBAdvanced Version: 2.1.0 with this integration installed.
    Description: Give your users an option to collapse the sidebars of your integrated vBulletin Forum & vBAdvanced CMS.
    Details: 1 Template Change and 1 Product XML (with 1 Plugin, 2 Settings, 4 Phrases and 0 Template).
    Difficulty: very easy (plugin product and one template change).
    Author: Milad
    Upgrading: If you upgrade from 1.0.0, I prefare you uninstall the product (Because the product ID was changed) and revert adv_portal template, then reinstall it as the following instructions.
    Installation:
    1. Import product-collapse_sidbars_vba.xml into your PRODUCTS by going to
      Plugin System -> Manage Products -> Add/Import Product
      IF YOU ARE UPGRADING, be sure to set "Allow Overwrite" to "Yes".
    2. Upload 4 images (left_vbacollapse.gif, left_vbacollapse_collapsed.gif, right_vbacollapse.gif and right_vbacollapse_collapsed.gif) to forum/images/buttons directory.
    3. In adv_portal template do
      1. Find:
        [html]width="$vba_style[portal_leftcolwidth]"[/html]
        Replace with:
        [html]width="$vba_style[portal_leftcolwidth]" id="collapseobj_left_sidebar" style="{$vbulletin->left_sidebar_style}"[/html]
      2. Find:
        [html]width="$vba_style[portal_rightcolwidth]"[/html]
        Replace with:
        [html]width="$vba_style[portal_rightcolwidth]" id="collapseobj_right_sidebar" style="{$vbulletin->right_sidebar_style}"[/html]
      3. Find:
        [html]$home[centerblocks][/html]
        Add above:
        [html]<if condition="$show[left_column] and $vboptions[allow_collapse_left_sidebar]">
        <a href="#top" onclick="return toggle_collapse('left_sidebar')" style="float:$stylevar[left]; margin-bottom:2px"><img alt="" border="0" src="$stylevar[imgdir_button]/$stylevar[left]_vbacollapse{$vbulletin->left_sidebar_image}.gif" id="collapseimg_left_sidebar" /></a>
        </if>
        <if condition="$show[right_column] and $vboptions[allow_collapse_right_sidebar]">
        <a href="#top" onclick="return toggle_collapse('right_sidebar')" style="float:$stylevar[right]; margin-bottom:2px"><img alt="" border="0" src="$stylevar[imgdir_button]/$stylevar[right]_vbacollapse{$vbulletin->right_sidebar_image}.gif" id="collapseimg_right_sidebar" /></a>
        </if>[/html]
    4. Click to receive updates.
    5. Done! Thank you for installing.
    Changelog:
    • Feb, 21st 2006: (1.0.0)
      • Initial release
    • Feb, 23rd 2006: (1.0.1)
      • Appearance improved, see this post. (screenshots updated)
      • Add the abbility to collapse both left and right sidebars.
      • Add two options in "Style & Language Settings" to Allow/Disallow Collapsing Left/Right sidebar.
      • Arrows Directions work in both RTL & LTR forums.
      • Hack was renamed "Collapse Left Sidebar of vBA CMS" -> "Collapse Sidebars of vBA CMS".
    Support is free-time controlled.
    Default Re: [Hack] Collapse Left Sidebar of vBA CMS (1.0.0)
    Get Support HERE
    I assume this is for people that have integrated a sidebar into the forum pages themselves e.g. forums/index.php, forums/forumdisplay.php, and forums/showthread.php, Yada Yada.
    I know, stupid question, but...
    Yes you'r right
    Thread updated.
    1.0.1 released.
    Very nice .. thanks for releasing ..
    A suggestion .. Can you make it to remember each collapse per page?
    Nov 2004
    108
    Wonderful hack, I have it installed and my members think very highly of it.
    One question though, how come in Firefox the images appear as in your screenshots, to each side of the centreblock, but in IE they appear just above the centreblock??
    Not a problem or error, just curious.
    Patience is something I learned the hard way!
    I drove National Express coaches for 6 years....
    Quote Originally Posted by Slave
    This will require you to collapse each page.
    I think it is not good to do.
    Quote Originally Posted by gothic1213
    It designed to appear above the central block, and it looks different in FF.
    I think it looks better in IE.
    In the next version, appearance will be united.
    Nov 2004
    108
    Quote Originally Posted by Milad
    Very good news, I look forward to it. Thankyou.
    Nov 2004
    108
    Any news on the update for this brilliant mod ??
    does this work on the front portal page? (non-vbulletin pages)
    This Hack doesn´t works with CMPS 3.0...
    The adv_portal-template-code was changed at 3.0. Now the sidebar collapsed, but by clicking on another forumsite (or refreshing the site) the sidebar will be showing up automatically... I tried to edit the template, but it doesn´t works.
    Can you make this hack compatible to CMPS 3.0, please!?
    Is there any way to make it as an option in User CP?
    I mean to enable or disable vBAdvanced columns...
    Aure entuluva!
    http://www.dipsizkuyu.net - Turkey's fountain of knowledge.
    Seems to work ok for me in 3.0.1 . State of column is remember upon page refresh.
    The only thing need to work on is the spacing when the column is expanded.
    Quote Originally Posted by Carsten View Post
    I'm getting the same problem
    Please can anyone help - this is a BRILLIANT Hack that needs updating
    Mar 2006
    no updates to this?
    Jan 2006
    10
    Is there a way to set permissions per usergroup for this hack? I'd like to reward a certain usergroup with being able to collapse sidebars, whereas regular and gu3ests cannot collapse.
    Greg Cagle
    Site Admin
    http://www.ChipTalk.net
    May 2010
    Hey guys,
    Anyone who got a solution, please share it!
    Thanks for those who tried.
    Smile, life is tooooooooo short!
    Ammar,
    Syrian Clinic Medical Information Guide
  1. left sidebar in Links
    By CSS59 in forum "How Do I..." Questions
    Last Post: 08-04-2005, 01:51 PM
  2. Flash Header & Left SideBar
    By DGTLMIK in forum Troubleshooting / "How do I..." Questions
    Last Post: 04-07-2005, 05:41 PM
  3. SideBar to the left of the Breadcrumb Bar
    Last Post: 02-17-2005, 03:49 PM
  4. Opinions needed - collapsable left sidebar
    By Alan @ CIT in forum Add-On Modules & Modifications
    Last Post: 01-03-2005, 12:13 PM
  5. Left sidebar on forum home doesn't work
    By golfrewind in forum Troubleshooting / "How do I..." Questions
    Last Post: 07-25-2004, 09:43 PM
