Results 1 to 12 of 12
Thread: Navigation problems
    Jan 2006
    Örebro, Sweden
    39
    Default Navigation problems
    Hi
    I noticed this after installing the new version of Link Directory ( 1.0.1 )
    Powered by: vBadvanced Links Directory v$version
    Also my main navigation seems to be confused
    My forum is installed at http://www.mysite.com/forum/ and my Link Directory is under http://www.mysite.com/Links/
    But when i acess my Link Directory my navigation also changes, for example http://www.mysite.com/forum/usercp.php changes to http://www.mysite.com/links/usercp.php
    What am I doing wrong?
    Default Re: Navigation problems
    I don't think you did anything wrong as I too am receiving the same errors as you are. It might have something to do with how links_global.php calls to the forum. These are the issues so far:
    navbar links (not pointing to forum path)
    login (same with navbar)
    vbphrasing (for vBa Links version)
    Can we please have these issues addressed? Again our issues are:
    1. Powered by: vBadvanced Links Directory v$version (reverting does not apply since this is with default templates + unedited PHP files). Also, I've reuploaded all files + uninstalled and reinstalled several times.
    2. Navbar issue (does not recognize login nor do the links point to the right path in any of the Link pages).
    Attachments below show: 1) The correct navbar/login (*Note that the correct one has the user logged in and have the link "Forum Rules") and 2) The incorrect navbar/login.
    Apr 2006
    i have the same errors, can anybody help us ??????
    Jun 2006
    Hi, everyone..
    It seems others have found the solutions for this navigation problem ?
    can share with me ?... I had tried to check my links setting... and it seems I had set it right... but still have problem.
    for example (pointing to usercp.php under link directory)
    http://www.smartforum.jp/link/usercp.php
    Anybody kindly tell me what I should check ?
    Jun 2006
    Hi... Why Nobody reply ? ...
    is it Nobody knows the answer ?... or .. do I miss something ?
    I read that somebody recommend to check the link setting... I checked... I think I had set it up properly.. full path... but still not work... so... maybe there is another place to set ?
    Please... where is the support ?....
    21
    I'm having the same issues. I'll keep looking around this forum for an answer, but this is the first post I found that addressed my issues.
    Jun 2006
    I have this problem also.
    Have the same problem as well...
    I came on here tonight looking for the solution to this problem and it seems that I'm not the only one having this issue. Will now have to wait and see about this issue getting resolved.
    Hi Brian, well I ran this query and the results were (0) rows effected. I'm still having all sorts of problems with users pointing back to the NAV bar.
    UsersCp goes back to the Links area and casues an error message, and most of the others are pointing back to the links folder rather then the forum itself.
    I have checked and cannot seem to find the solution to this issue now, and have no clue where to start and how to fix this, so I'm leaving this to the experts here now.
    Thanks again, and hope there is an easy soloution to this.
    Dennis
    Your footer seems to be showing the correct version now... That's strange that it didn't show any rows updated when you ran the query, but I guess that doesn't matter as long as it's displaying the version now.
    For the links, see this thread:
    http://www.vbadvanced.com/forum/showthread.php?t=18042
  1. Added pages and site navigation problems.
    By chiaa in forum "How Do I..." Questions
    Last Post: 04-11-2007, 12:27 AM
  2. Navigation
    By Kasho in forum "How Do I..." Questions
    Last Post: 01-04-2006, 04:48 PM
  3. Problems with Site Navigation Module
    By Igon in forum Troubleshooting & Problems
    Last Post: 09-21-2005, 04:58 PM
  4. v2 navigation.php bug?
    By RBasil in forum Troubleshooting & Problems
    Last Post: 06-07-2005, 03:32 PM
