Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 98
Thread: Countdown Module
  1. #21
    Default Re: Countdown Module
    Hi
    What if I have more than one event?
    can I use it to shoe more than one countdown, say:
    event1: this much time
    event2: this much more time
    Thanx
  2. #22
    Nov 2006
    Texas, USA
    27
    Well this really sucks. I have waited over a week for some kind of support from the the maker of this module and still haven't been able to get it working. I installed it exactly how the instructions say and it does not work. I verifyed all the links are correct and they are
  3. #23
    Nov 2006
    Texas, USA
    27
    well, after a week of trying to figure it out I got the basic count down feature to work, but I had to change the module file type to the correct one because it was not recognizing the module file included as a valid module file..
    I have no idea why or how this happened, but at least I got it working....
  4. #24
    Dec 2006
    Hello,
    i have a problem, the error countdown display :
    NaN Days, NaN Hours,
    NaN Minutes, NaN Seconds.
    please help
  5. #25
    Jan 2006
    Holland
    30
    Quote Originally Posted by angeloespo View Post
    Hello,
    please help
    The Countdown uses AM and PM.
    So if u enter 20.00 PM you get this message.
    Correct it to 08.00 PM or AM
  6. #26
    Mar 2006
    Could anyone please tell me what am i doing wrong?
    It keeps saying that this is not a valid module when I try to install ?
    The version I am using is 3.5.4
  7. #27
    Quote Originally Posted by Nemes View Post
    Are you going to the plugin and products, click on manage products and then click on add/import products? If not that could be your problem.
  8. #28
    Dec 2006
    22
    Hey I am using vB 3.6.4 with vBadvanced CMPS v2.2.1 and I have installed this module followed all the steps and im sure I did everything right. But still it shows a very wierd date. See my website here: http://silentium-guild.org/cmps_index.php
    As you can see on the countdown it says over 500 days and I have no idea why.
    Heres the code for my thingie:
    <td class="$bgclass"><div align="center">
    <font size="-2"><script language="JavaScript">
    TargetDate = "30/11/2006 10:15 PM UTC-0500";
    CountActive = true;
    CountStepper = -1;
    DisplayFormat = "%%D%% Days, %%H%% Hours, <br>%%M%% Minutes, %%S%% Seconds.";
    FinishMessage = "It is finally here!";
    </script>
    <script language="JavaScript" src="http://www.silentium-guild.org/forums/clientscript/countdown.js"></script></td></tr>
    My forums time is set to GMT+1
    Any help appriciated.
  9. #29
    Quote Originally Posted by kapli View Post
    CountActive = true;
    CountStepper = -1;
    </script>
    make your target date 11/30/06, or better yet pick a date in the future
  10. #30
    Dec 2006
    22
    Ah.. I understand now ^^
    Thanks a lot that countdown looks really nice
  11. #31
    Mar 2006
    Quote Originally Posted by K D Umbaugh View Post
    Yup, Sorry been away a little so Just got back. I did use the add/edit modules in the VBA options.
    It's obviously working as none else is having the issue, I will have to try again.. brb
    thanks for the quick reply though ..
  12. #32
    Mar 2006
    Yeah this is still not working. The steps I have done are as follows.
    1. Uploaded countdown.js to the client script folder.
    2. Navigated to the admincp > Vba Cmps > Download / Upload Module
    3. In the "Upload Module" area Selected Browse and selected the "countdown.module" file as came with the .zip file.
    4. Set "Active" to yes
    5. Set "Update All Pages" to yes
    6. Set "Style to Install templates to" too default style (default is custom style but thats another story and sure it wont cause this issue)
    7. Left "All usegroups" on Yes as this is default
    8. Hit submit
    I get this error: The file you have uploaded is not a valid module file.
    My forum is currently
    Admin Control Panel (vBulletin 3.5.4)
    vBulletin Version 3.5.4
    Powered by vBadvanced CMPS v2.1.0
    What version on CMPS does this require as I assume this is probably my issue
    Look forward to hearing from you, and thanks again for the help
    Regards
  13. #33
    May 2006
    This isn't glorify code, he got it off another site and removed the copyright then posted it here.
  14. #34
    Wrongo rogers. I did figure out how to add this to VBA, but I used the original countdown.js script that was sent to me that worked on another site not using VBA. I claim no ownership of it, and just figured out how to make it work with the portal. Stuff your accusations. I did this for the benefit of the community, I myself did not benefit. If there is an original copyrighted version, then I'd ask the mods to delete this thread.
  15. #35
    8. Hit submit
    Regards
    I don't know why it's not accepting the module, This guy had the same prob but changed the file type. I have no idea how tho.
    Link
  16. #36
    After Googling Countdown.js, I did find an original .js file here.
    The only difference is an author and modified credit in the top of the script. First post is updated. The script is NOT copyrighted, and I don't appreciate the accusation of a doctored script on my part.
  17. #37
    Nov 2006
    I am unable to get this to work, shows up but no timer? any ideas?
    <tr
    td class="thead"><div align="center"><img src="http://www.projektgerman.com/images/cadwizgtg.jpg" width="454" height="301"></div></td>
    tr>
    TargetDate "02/04/2007 02:00 PM CST-0600";
    CountActive true;
    CountStepper = -1;
    DisplayFormat "%%D%% Days, %%H%% Hours, <br>%%M%% Minutes, %%S%% Seconds.";
    FinishMessage "It is finally here!";
    script>
    script language="JavaScript" src="http://www.projektgerman.com/forums/clientscript/countdown.js"></script></td></tr
  18. #38
    Dec 2006
    9
    I had the same problem - I went to the posted origonator of the countdown.js script and used that instead - all now working
    Thanks for the mod!
  19. #39
    26
    For whatever reason I could not get this to work if the countdown.js was located anywhere on my site. As soon as I used the script's creator's site it works fine. No clue why. I checked my path several times, even tried it in a different folder...no dice.
  20. #40
    Feb 2007
    6
    hi! i have the countdown module showing but the timer is not there...
    the source of the script looks right as well...
    <script language="JavaScript" src="http://www.cricketime.com/clientscript/countdown.js"></script>
    can you please let me know what im doing wrong? thanks!
  1. Req: Countdown module vba CMPS using the calendar
    By The_Rayman in forum Module & Modification Discussion & Requests
    Last Post: 02-12-2007, 01:57 PM
  2. Module: Countdown to certain date
    By 58sniper in forum Add-On Modules & Modifications
    Last Post: 10-26-2005, 01:57 PM
  3. [req] countdown module
    By Milk Man in forum Add-On Modules & Modifications
    Last Post: 10-14-2005, 08:47 PM
  4. my countdown module problems
    By Nephalim in forum Module & Modification Discussion & Requests
    Last Post: 09-17-2005, 08:53 AM
  5. using a vba function (countdown) without adding module
    By axi in forum Troubleshooting / "How do I..." Questions
    Last Post: 02-27-2005, 01:33 AM
