Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 98
Thread: Countdown Module
  1. #41
    Feb 2007
    6
    Default Re: Countdown Module
    never mind... found the problem... thanks for the module glorify!
  2. #42
    Jul 2006
    Quote Originally Posted by glorify View Post
    After Googling Countdown.js, I did find an original .js file here.
    The only difference is an author and modified credit in the top of the script. First post is updated. The script is NOT copyrighted, and I don't appreciate the accusation of a doctored script on my part.
    I used this js script and it finally started working for me
  3. #43
    Mar 2006
    I don't know why it's not accepting the module, This guy had the same prob but changed the file type. I have no idea how tho.
    Link
    Ah well thanks for your efforts, I will keep trying to work it out. I am still not having much luck on it.
  4. #44
    Well I give up...
  5. #45
    Question Re: Countdown Module
    I was able to install this and followed the instructions closely, however the only thing showing on my homepage is just "countdown" not the actual timer. I'm attaching a screen cap (see above moon phase). Can you tell me what else I need to do?
  6. #46
    Quote Originally Posted by Jenn View Post
    Did you set the date and time for the future
  7. #47
    yes I set it up to contdown to Thanksgiving.
  8. #48
    I tried this module on 3.6.8 and VBa CMPS 3.0 RC2 and all I get is the title block nothing in the countdown window.
    The target date is set as:
    TargetDate = "10/03/2008 12:00 AM UTC-0500";
    And I tried the location of countdown.js in the last line using both the fully qualified domain name http://www.blah.blah.blah.com/clientscript/countdown.js as well as I tried ti by the server path /home/public_html/clientscript/countdown.js and it did not work either way.
    Is this a dead module?
  9. #49
    Feb 2007
    Thank you
  10. #50
    172
    Quote Originally Posted by KenDude View Post
    Me too. Anyone know why it isn't working?
  11. #51
    172
    I got it to work!! Yay me!!
    This is my template code, I added "id=clock" to the div. class can be changed to your own class or removed.
      <td class="$bgclass"><div id="clock" class="smallfont" align="center">
    Clock count</div>
    <script type="text/javascript">
    TargetDate = "02/17/2008 03:40 PM";
    BackColor = "red";
    ForeColor = "white";
    CountActive = true;
    CountStepper = -1;
    LeadingZero = true;
    DisplayFormat = "%%D%% Days, %%H%% Hours, <br />%%M%% Minutes, %%S%% Seconds.";
    FinishMessage = "Game Time!!";
    </script>
    <script type="text/javascript" src="http://www.redandwhiteonline.com/forum/clientscript/countdown.js"></script>
    </td></tr>
    This is my countdown.js. written by the same person, just slightly different to the one in post #1.
    Author: Robert Hashemian
    http://www.hashemian.com/
    You can use this code in any manner so long as the author's
    name, Web address and this disclaimer is kept intact.
    function calcage(secs, num1, num2) {
      s = ((Math.floor(secs/num1))%num2).toString();
      if (LeadingZero && s.length < 2)
        s = "0" + s;
      return "<b>" + s + "</b>";
    function CountBack(secs) {
      if (secs < 0) {
        document.getElementById("clock").innerHTML = FinishMessage;
        return;
      DisplayStr = DisplayFormat.replace(/%%D%%/g, calcage(secs,86400,100000));
      DisplayStr = DisplayStr.replace(/%%H%%/g, calcage(secs,3600,24));
      DisplayStr = DisplayStr.replace(/%%M%%/g, calcage(secs,60,60));
      DisplayStr = DisplayStr.replace(/%%S%%/g, calcage(secs,1,60));
      document.getElementById("clock").innerHTML = DisplayStr;
      if (CountActive)
        setTimeout("CountBack(" + (secs+CountStepper) + ")", SetTimeOutPeriod);
    function putspan(backcolor, forecolor) {
     document.write("<span id='cntdwn' style='background-color:" + backcolor +
                    "; color:" + forecolor + "'></span>");
    if (typeof(BackColor)=="undefined")
      BackColor = "white";
    if (typeof(ForeColor)=="undefined")
      ForeColor= "black";
    if (typeof(TargetDate)=="undefined")
      TargetDate = "12/31/2020 5:00 AM";
    if (typeof(DisplayFormat)=="undefined")
      DisplayFormat = "%%D%% Days, %%H%% Hours, %%M%% Minutes, %%S%% Seconds.";
    if (typeof(CountActive)=="undefined")
      CountActive = true;
    if (typeof(FinishMessage)=="undefined")
      FinishMessage = "";
    if (typeof(CountStepper)!="number")
      CountStepper = -1;
    if (typeof(LeadingZero)=="undefined")
      LeadingZero = true;
    CountStepper = Math.ceil(CountStepper);
    if (CountStepper == 0)
      CountActive = false;
    var SetTimeOutPeriod = (Math.abs(CountStepper)-1)*1000 + 990;
    putspan(BackColor, ForeColor);
    var dthen = new Date(TargetDate);
    var dnow = new Date();
    if(CountStepper>0)
      ddiff = new Date(dnow-dthen);
    else
      ddiff = new Date(dthen-dnow);
    gsecs = Math.floor(ddiff.valueOf()/1000);
    CountBack(gsecs);
    Hope this helps.
  12. #52
    May 2008
    101
    How is this module working?
    Any updates?
    Thanks,
    Jill
  13. #53
    172
    Quote Originally Posted by Chief Thunder View Post
    Any updates?
    Thanks,
    Jill
    Beautifully. see the SydneySwans link in my sig. Top of right column, ticking away nicely.
  14. #54
    Nov 2007
    6
    does this work for 3.7.x and vbadvanced 3.0.x??? this is my code and its not working (no count down appears in the countdown box)
      <td class="$bgclass"><div align="center">
    <font size="-2"><script language="JavaScript">
    TargetDate = "8/31/2009 10:15 PM UTC-0500";
    CountActive = true;
    CountStepper = -1;
    DisplayFormat = "%%D%% Days, %%H%% Hours, <br>%%M%% Minutes, %%S%% Seconds.";
    FinishMessage = "It is finally here!";
    </script>
    <script language="JavaScript" src="http://www.ready2rumble.org/clientscript/countdown.js"></script></td></tr>
  15. #55
    I'm having same problem. Can someone please help i really like this mod
  16. #56
    May 2008
    6
    Works very well under VB 3.7.2! Thank you very much, rwoscott!
  17. #57
    Using the code from rwoscott on post #51 works perfectly on VB3.7.2, VB Adv 1.0.2 & CMPS 3.0.2 .
  18. #58
    Would anyone be able to tell me how to change the size/colour of the countdown text? Have tried a couple of ways including the span method suggested by the writer of the javascript, but to no avail.
  19. #59
    172
    Quote Originally Posted by CFodder View Post
    I never got that to work either.
    Will have a better look when I get a chance.
  20. #60
    At least it's not just me then .
  1. Req: Countdown module vba CMPS using the calendar
    By The_Rayman in forum Module & Modification Discussion & Requests
    Last Post: 02-12-2007, 01:57 PM
  2. Module: Countdown to certain date
    By 58sniper in forum Add-On Modules & Modifications
    Last Post: 10-26-2005, 01:57 PM
  3. [req] countdown module
    By Milk Man in forum Add-On Modules & Modifications
    Last Post: 10-14-2005, 08:47 PM
  4. my countdown module problems
    By Nephalim in forum Module & Modification Discussion & Requests
    Last Post: 09-17-2005, 08:53 AM
  5. using a vba function (countdown) without adding module
    By axi in forum Troubleshooting / "How do I..." Questions
    Last Post: 02-27-2005, 01:33 AM
