Thread: Mysql error
    Default Mysql error
    Hello,
    I installed and uninstalled vBa Links Directory 1 on my vb 3.6 forum.
    When I try to install it again, I get this error :
    Database error in vBulletin 3.6.0:
    INSERT INTO phrase (languageid, varname, text, fieldname) VALUES (0, 'setting_global_navbar_replace_title', 'Navbar Replacements', 'vbsettings');
    MySQL Error : Duplicate entry 'setting_global_navbar_replace_title-0-vbsettings' for key 2
    Error Number : 1062
    Date : Tuesday, October 17th 2006 @ 12:45:43 PM
    Script : http://virusphoto.com/admincp/vbalinks_install.php
    Referrer : http://virusphoto.com/admincp/vbalinks_install.php
    IP Address : 86.120.165.157
    Username : Jeff
    Classname : vb_database
    I tried to uninstall and install again, but I still get the same error.
    How can I fix that ?
    Thanks.
    Default Re: Mysql error
    Is there any way to fix that ?
    Thanks.
    Try looking in the admincp/vbalinks_install.php file for this line:
    $checkglobal $db->query_first("SELECT grouptitle FROM " TABLE_PREFIX "adv_settinggroup WHERE grouptitle = 'adv_global'");
    Replace with this:
    $checkglobal $db->query_first("SELECT grouptitle FROM " TABLE_PREFIX "adv_setting WHERE grouptitle = 'adv_global'");
    Then try to un-install and re-install again.
    Done. Now i get this error :
    INSERT INTO adv_settinggroup VALUES ('adv_global', 1);
    MySQL Error : Duplicate entry 'adv_global' for key 1
    Error Number : 1062
    Date : Wednesday, October 18th 2006 @ 09:21:03 PM
    Username : Jeff
    How can I fix it ?
    Strange... I don't see how you would get that, but you should be able to replace this line:
    $db->query_write("INSERT INTO " TABLE_PREFIX "adv_settinggroup VALUES ('$name', $gid)");
    With this:
    $db->query_write("INSERT IGNORE INTO " TABLE_PREFIX "adv_settinggroup VALUES ('$name', $gid)");
    And that will keep it from erroring out.
    Though is there any reason why you're installing v1.0? 2.0 was just released a few weeks ago and includes quite a few new options and features.
    issue fixed, thanks.
  1. another MySQL error
    By Delphivi in forum Troubleshooting & Problems
    Last Post: 10-09-2006, 02:37 PM
  2. MySQL error in 2.0
    Last Post: 10-04-2006, 08:52 PM
  3. Please HELP MySQL ERROR!!!
    By gtx2 in forum Troubleshooting & Problems
    Last Post: 07-07-2006, 11:13 PM
