Thread: SQL Errors
    31
    Default SQL Errors
    I installed 2.0 RC and received tons of SQL errors in fact it did not migrate over my old data. I restored the data and not I'm reciving SQL errors. HELP!
    Database error in vBulletin 3.6.4:
    SELECT links.linkid
    FROM links AS links
    WHERE suspended = 0 AND valid = 1
    ORDER BY dateline DESC, linkid DESC
    LIMIT 1,3,7,14,30,60;
    MySQL Error : You have an error in your SQL syntax. Check the manual that
    corresponds to your MySQL server version for the right syntax to use near
    '7,14,30,60' at line 6
    Error Number : 1064
    Date : Monday, November 27th 2006 @ 06:32:50 AM
    Script : http://www.vbli.com/forums/links/bro...hp?do=newlinks
    Referrer :
    IP Address : 66.249.72.113
    Username : Unregistered
    Classname : vb_database
    Default Re: SQL Errors
    You would need to also restore your adv_setting table if you're trying to downgrade.
    Also, what were the SQL errors you receiving after the upgrade? Were you getting them from the upgrade script, or the normal links directory files?
    31
    It seeming not to remove the none adv_* links tables. I noticed this when all my 900+ links were gone, however still in the DB. If I restore the adv_setting table now will it upset anything none links related? I mean I've been working on this since Friday and fear full of screwing up again.
    I think I may have and I'm only admiting this because I'm honest selected install instead of upgrade, but I'm not sure anymore.
  1. A few Errors... Need a little help please
    By web-rocket in forum Troubleshooting & Problems
    Last Post: 06-01-2006, 05:04 PM
  2. Errors!
    By mike12345 in forum Troubleshooting & Problems
    Last Post: 05-07-2006, 03:26 AM
  3. I can't fix these errors! Please help.
    By konabiker47 in forum Troubleshooting & Problems
    Last Post: 01-17-2006, 06:08 PM
  4. Array errors and SQL errors
    By Richard-HH in forum Troubleshooting / "How do I..." Questions
    Last Post: 11-14-2004, 02:49 PM
