Will modules that pull info from the forums or other systems (photopost, etc) work in Blogicles, or will new ones need to be crafted?
Yes, for the most part any CMPS modules should work fine with vBa Blogicles.
Currently I've tested a few that do not, I'm working to compile a list.
We would have to make a new module for use in the blogicles right?
Yes. You should be able to use the "Download / Upload Module" link to donwload the modules from the CMPS, then the same link under your vBa Blogicles to upload the modules after they are downloaded from the CMPS.
