Results 1 to 14 of 14
Thread: Adding bb code problem
    Apr 2006
    Detroit
    49
    Default Adding bb code problem
    If I want to add new bbcode module, no problem, but if I click on add link, image or amail link, I get a 404 page not found within the pop-up to add link or image or email link...Can someone please help me correcting this issue?, Please...
    Also, in usercp/edit options/Miscellaneous Options, I as well as all site members, even in admincp, can only use Standard or basic editor. If we use Enhanced, we cant copy from any bbcode, post or thread while making...This is another issue I need help addressing, Please....Thanks
    Default Re: Adding bb code problem
    I have the same problem. It just started with the 3.6.5 update. If I try to add an image I get the error attached. I have to use [img] tags as a work around. Any suggestions?
    Apr 2006
    Detroit
    49
    Thats what I am hoping to get info on here, vb.com sent me away.(says they dont support modded sites)
    Are you running 3.6.5??
    Apr 2006
    Detroit
    49
    yepper, I even built a test site with nothing on it at all, & same thing happens
    Quote Originally Posted by blind-eddie View Post
    It must be related to the 3.6.5 update.
    Thank you for pointing this out. It looks like vB added a new pop-up type window in 3.6.5 for IE7 users. Unfortunatly they've hard coded the URL for that window within their javascript files and there's not an easy way that I'm aware of to keep this window without modifying vB's javascript file to add the full URL. However, it seems that we can "trick" vB into thinking an older version of IE is being used and have it go back to using the old pop-up window when you're on the CMPS admin page. I've just applied the fix to the files here, so anyone that's having the problem should be able to download the files from here again and replace your admincp/vba_cmps_admin.php file with the one from the package. Or, if you'd rather make the change yourself, just look in that file for this code:
                    echo '<style type="text/css"><!--
                        .wysiwyg
                            background-color: '
    $stycolor['wysiwyg_bgcolor'] . ';
                            color: '
    $stycolor['wysiwyg_fgcolor'] . ';
                            font: 10pt verdana, geneva, lucida, \'lucida grande\', arial, helvetica, sans-serif;
                    </style>'
    Replace with this:
                        .wysiwyg
                            background-color: '
                            color: '
                    </style>
                    <script type="text/javascript">
                        var is_ie7 = false;
                    </script>'
    And that should do the trick.
    Apr 2006
    Detroit
    49
    post deleted...Thank You!!!!
    That did the job, Thank you...I last item please, did you look into the second question of my very first post?
    Is this just with the CMPS, or everwhere you see the editor?
    Apr 2006
    Detroit
    49
    everywhere,try it on one of the 1st 2 site links I have.
    If it's happening everywhere then that wouldn't have anything to do with the CMPS and you would need to ask for help at vbulletin.com.
    Apr 2006
    Detroit
    49
    I went there, they wouldn't help me because my site is modded, so I built a test site in minutes, with nothing on it, and it was still doing the same....They went to my test site noticed they wasn't having that problem, They went on to tell me it was due to my operating system & browser settings, they tell me to upgrade to xp pro & use only default settings in my browser.....I already have PX pro, & use only default settings in my browser..I say BS...This is happening to 277 other site members including you...set your usercp edit options to Enhanced on your site & see if it also happens there....Thanks
    Apr 2006
    Detroit
    49
    That's still something that you will have to take up with them. We do not support other companies products.
  1. Problem w/ Custom BB Code Editor Images
    By indie in forum Bugs From 2.2.1
    Last Post: 12-08-2007, 03:19 AM
  2. Adding module code to the navbar template
    By gopherhockey in forum "How Do I..." Questions
    Last Post: 11-06-2005, 09:40 PM
  3. Adding php code to templates !
    By DOMIN8 in forum Troubleshooting / "How do I..." Questions
    Last Post: 05-15-2005, 01:57 PM
  4. Problem with vbcode, img code and html for news on front page
    By Bambi in forum Troubleshooting / "How do I..." Questions
    Last Post: 11-07-2004, 12:58 PM
  5. Problem adding pages
    By gilbert in forum Troubleshooting / "How do I..." Questions
    Last Post: 11-06-2004, 04:14 PM
