Thread: Style Issue
    May 2004
    145
    Default Style Issue
    When intergrating modules into other forum pages it blows the page off to the right. Causing the site to have to scroll to the right to see the whole site. Any fix for this?
    Itworx4me
    Default Re: Style Issue
    That's usually caused when you're trying to cram too much info into too small of a space... Can you link me to a page where you're having this problem?
    May 2004
    145
    Hello Brian,
    It worked just fine with the old cmps and with the new one it just pushes the info out the right side.
    http://www.nitromater.com/forumindex.php
    Thanks,
    Itworx4me
    It looks like it's the "show template comments" setting (or something like that) that's messing up the layout. The source of the page shows this as the first line:
    <!-- BEGIN TEMPLATE: adv_portal -->
    When that's removed, it aligns properly.
    May 2004
    145
    Hello Brian,
    I have done a template search and found nothing. I then did a file search on the folder I downloaded from you and there was nothing in there that had <!-- BEGIN TEMPLATE: adv_portal -->. How do I get rid of this text?
    Thanks,
    Itworx4me
    May 2004
    145
    ok I figured out how to turn off comments. But why does this happen when its turned on? It wasn't that way before I upgraded to 3.0 RC1. Will there be a fix?
    Thanks,
    Itworx4me
    I see how that's happening now. The 'adv_portal' template is called in a different manner when it's integrated with other pages, so the comment isn't being added in the right place. It should be easy enough to just disable the template comment for that template and fix the problem though. If you'll look in your forum/includes/vba_cmps_include_top.php file for this line:
    eval('$output = "' fetch_template('adv_portal') . '";');
    And add this right Above it:
    $vbulletin->options['addtemplatename'] = 0
    Then that should take care of the problem. I've also updated the download package here to include this change.
  1. Defaukt style issue
    By cyberghoser1 in forum "How Do I..." Questions
    Last Post: 06-04-2006, 05:08 AM
  2. Style Issue
    By brady in forum Troubleshooting & Problems
    Last Post: 02-07-2006, 03:15 PM
  3. Ok how do i change the vbA style from vb default style
    By selene in forum "How Do I..." Questions
    Last Post: 11-30-2005, 02:29 PM
  4. strange style issue
    By wintermute in forum Troubleshooting / "How do I..." Questions
    Last Post: 11-20-2004, 05:13 PM
