Results 1 to 12 of 12
Thread: News Module Not Working
    Default News Module Not Working
    I updated my vbadvanced to 3.0 today and get a database error when the news module is active. I do not get a database error when the news module is not active. The error I get is below:
    Database error in vBulletin 3.6.7:
    SELECT IF(votenum >= 2, votenum, 0) AS votenum, IF(votenum >= 2 AND votenum != 0, votetotal / votenum, 0) AS voteavg, votetotal, thread.threadid, post.title, thread.replycount, postusername, postuserid, thread.dateline AS postdateline, sticky, thread.attach, thread.lastpostid, thread.lastposter, thread.lastpost, IF(views<=thread.replycount, thread.replycount+1, views) AS views, thread.forumid, post.postid, pagetext
    , allowsmilie, pagetext_html, hasimages, showsignature, sigparsed.signatureparsed, sigparsed.hasimages AS sighasimages, sigpic.userid AS sigpic, sigpic.dateline AS sigpicdateline, sigpic.width AS sigpicwidth, sigpic.height AS sigpicheight, NOT ISNULL(subscribethread.subscribethreadid) AS subscribed
    FROM thread AS thread
    LEFT JOIN post AS post ON (post.postid = thread.firstpostid)
    LEFT JOIN user AS user ON (user.userid = post.userid) LEFT JOIN postparsed AS postparsed ON (postparsed.postid = post.postid AND postparsed.styleid = 9 AND postparsed.languageid = 1) LEFT JOIN sigparsed AS sigparsed ON (sigparsed.userid = user.userid AND sigparsed.styleid = 9 AND sigparsed.languageid = 1)
    LEFT JOIN sigpic AS sigpic ON (sigpic.userid = post.userid) LEFT JOIN subscribethread AS subscribethread ON (subscribethread.threadid = thread.threadid AND subscribethread.userid = '4')
    WHERE thread.threadid IN(25775)
    ORDER BY sticky DESC,thread.dateline DESC
    LIMIT 1;
    MySQL Error : Column: 'hasimages' in field list is ambiguous
    Error Number : 1052
    Date : Tuesday, May 22nd 2007 @ 07:33:57 PM
    Script : http://www.reeffrontiers.com/
    Referrer : http://www.reeffrontiers.com/
    IP Address : 67.183.147.136
    Username : MtnDewMan
    Classname : vb_database
    Any ideas?
    Default Re: News Module Not Working
    That's an error that could happen when you have signatures and the post cache options enabled in your news module. The forum/modules/news.php file in the package here has been updated with the fix, so if you'll download it again and replace that file with the new one, that should take care of the problem.
    Thank you, I will re-download tonight and give it a shot and will report back if it is successful.
    It worked without giving me database errors Thanks It will not show signature images with the IMG tags however. It just shows the IMG tags with the link to the image within the tags. Not the image itself. But at least it works without database errors now
    Thanks again
    Apr 2007
    11
    Trying to put the sorting in News Modul by Last Post I am getting this error
    Database error in vBulletin 3.6.4:
    SELECT thread.threadid, post.title, thread.replycount, postusername, postuserid, thread.dateline AS postdateline, sticky, thread.attach, thread.lastpostid, thread.lastposter, thread.lastpost, IF(views<=thread.replycount, thread.replycount+1, views) AS views, thread.forumid, post.postid, pagetext, user.*
    , allowsmilie, pagetext_html, postparsed.hasimages, NOT ISNULL(subscribethread.subscribethreadid) AS subscribed
    FROM vbthread AS thread
    LEFT JOIN vbpost AS post ON (post.postid = thread.firstpostid)
    LEFT JOIN vbuser AS user ON (user.userid = post.userid)
    LEFT JOIN vbpostparsed AS postparsed ON (postparsed.postid = post.postid AND postparsed.styleid = 5 AND postparsed.languageid = 4) LEFT JOIN vbsubscribethread AS subscribethread ON (subscribethread.threadid = thread.threadid AND subscribethread.userid = '52')
    WHERE thread.threadid IN(155,616,1258,1991,2169,2247)
    AND thread.forumid NOT IN(29)
    ORDER BY lastpost ASC
    LIMIT 6;
    MySQL Error : Column 'lastpost' in order clause is ambiguous
    Error Number : 1052
    Thank you for pointing that out. If you'll look in your modules/news.php file for this code:
                ORDER BY " . iif($mod_options['portal_news_sticky'], 'sticky DESC,') . iif($mod_options['portal_news_orderby'] == 'postdateline', 'thread.dateline', $mod_options['portal_news_orderby']) . " $mod_options[portal_news_direction
                ORDER BY " . iif($mod_options['portal_news_sticky'], 'sticky DESC, ') . 'thread.' . iif($mod_options['portal_news_orderby'] == 'postdateline', 'dateline', $mod_options['portal_news_orderby']) . " $mod_options[portal_news_direction
    Then that should fix the problem.
    Apr 2007
    11
    Thanks Brian it works now.
    One more question, is it possible that news moduls shows the last post of thread I choosed? I was hoping that the sorting by last post will show the last posts of threads but it justs sorts the threads, still showing the first post of threads.
    Sorry, but there is not an option to show the last post instead of the first.
    Even after your news.php edit, I still get:
    Database error in vBulletin 3.6.8:
    			, allowsmilie, thread.iconid AS threadiconid, iconpath AS threadiconpath, NOT ISNULL(subscribethread.subscribethreadid) AS subscribed
    			 LEFT JOIN icon AS icon ON (icon.iconid = thread.iconid) LEFT JOIN subscribethread AS subscribethread ON (subscribethread.threadid = thread.threadid AND subscribethread.userid = '1')
    			WHERE thread.threadid IN(18735,18725,18724,18715,18714,18687,18684,18634,18696,18620)
    			ORDER BY lastpost DESC
    			LIMIT 10;
    Error Number : 1052
    Date         : Monday, August 20th 2007 @ 10:00:18 PM
    Script       : http://www.glorifythepast.com/
    Sounds like you didn't apply the change correctly. Can you post that section of code from your news.php file here?
    Yep. Did the edits twice on two different news.php's:
    $getnewsids = $db->query_read("
    				SELECT $ratingsql threadid, firstpostid FROM " . TABLE_PREFIX . "thread AS thread
    				WHERE visible = 1
    					AND open != 10
    					AND thread.forumid IN(" . implode(',', $mods['inforums']) . ")
    					" . iif($mod_options['portal_news_cutoffdate'], 'AND thread.dateline > ' . (TIMENOW - ($mod_options['portal_news_cutoffdate'] * 86400))) . "
    				ORDER BY " . iif($mod_options['portal_news_sticky'], 'sticky DESC, ') . 'thread.' . iif($mod_options['portal_news_orderby'] == 'postdateline', 'dateline', $mod_options['portal_news_orderby']) . " $mod_options[portal_news_direction]
    				$newslimit
    The only other thing I could guess is that the file is not being overwritten when you upload it as the code from the SQL error and the code you've posted are not the same.
  1. How Do i get the news module working?
    By ep13 in forum "How Do I..." Questions
    Last Post: 01-12-2007, 01:31 PM
  2. News module not working as expected
    By mferguson in forum Troubleshooting & Problems
    Last Post: 10-08-2005, 05:33 PM
  3. News not working
    By Todaysfishing in forum Troubleshooting / "How do I..." Questions
    Last Post: 04-07-2005, 05:12 PM
  4. News Module not working properly
    By enzo81 in forum Troubleshooting / "How do I..." Questions
    Last Post: 07-05-2004, 10:51 AM
