Thread: BB Code Module Options - Editior Problems
    Default BB Code Module Options - Editior Problems
    I enter info and the editior worked fine. Made changes and now it will not insert spaces between lines.
    Also, the button on the far right "switch editior" mode does not work.
    Default Re: BB Code Module Options - Editior Problems
    Thank you for pointing this out. It looks like the spacing issue with BB code modules is due to the WYSIWYG not having a style sheet linked up with it. There's not really a way to use the default style, but it looks like the code can at least be "tricked" into thinking it has one. If you'll look in your admincp/vba_cmps_admin.php file for this code:
    // Print Admin Header
    And add this right Above it:
    if ($type == 'bb_code')
    $extrahead .= '<link rel="stylesheet" type="text/css" href="" id="vbulletin_css" />';
    Then that should take care of the issue.
    For the "switch editor" button, I'm not sure there's going to be an easy way to make that work in the Admin CP. You can still switch between editor modes using your User CP settings though.
  1. BB Code Module Options save problems
    By TheHeartSmasher in forum Troubleshooting & Problems
    Last Post: 12-28-2006, 02:16 PM
  2. Replies: 2
    Last Post: 02-27-2006, 10:48 PM
  3. Icons in the BB Code Module Options not showing like the following
    By lsgworldl in forum Troubleshooting & Problems
    Last Post: 12-01-2005, 04:54 PM
  4. Problems with vB-Code and News Maximum Characters
    By Stefan in forum Troubleshooting / "How do I..." Questions
    Last Post: 08-14-2005, 01:05 AM
  5. No module options
    By jonno147 in forum Troubleshooting & Problems
    Last Post: 08-02-2005, 01:18 PM
