Thread: News and Signatures Images
    Jul 2004
    Default News and Signatures Images
    www.keepersoftheelements.com
    If I go to the actual post in the forums I can actually see the signature using any of the following structures:
    <img src='http://bla bla bla'>
    or
    [ IMG ]http://bla bla bla[ / IMG ] ** Without the spaces**
    or
    [ sigpic ][ / sigpic ] ** Without the spaces**
    Now If I go to the actual front page where the news post is viewed through the CMPS I can only use:
    All files are up to date. Only *hacks* to the forums are CMPS and 3 Flashchat integrations that are all added through the product system.
    I've done everything in thread http://www.vbadvanced.com/forum/showthread.php?t=22034 but has not worked for me.
    I'm working with current versions:
    CMPS v3.0 RC1
    vBulletin® Version 3.6.7 PL1
    Problem is reproducible before and after I setup Flashchat.
    Problem is reproducible with Flashchat on and off.
    Default Re: News and Signatures Images
    Thank you for pointing this out. There were a couple of code changes required to fix the problem, so I've went ahead and applied the fix to the download package here. If you'll download the files from the Members' Area here again and replace your forum/modules/news.php file with the updated one, that should take care of the problem.
    Jul 2004
    Thanks Brian. It is working somewhat better now.
    Only problem now is that when I use "[ sigpic ][ / sigpic ]" it's trying to link to the root directory instead of the forums directory. I've been trying to run down that rogue for hours now.
    Jul 2004
    Update:
    < img works
    [ img works
    [ sigpic is not doing the correct path as stated on my previous post.
    [ sigpic should output:
    http://*url*/forums/image.php?bla bla bla
    istead it is outputting:
    http://*url*/image.php?bla bla bla
    It looks like it's going to require a bit of work to get the [sigpic] tag working properly. I'll try to be sure that one is corrected with the next release though.
    Jul 2004
    Thank you very much Brian. Until then I can make sure the news posters do not use sigpic
  1. Signatures in news module
    By Stubentiger in forum Troubleshooting & Problems
    Last Post: 01-12-2007, 01:24 PM
  2. problem with the signatures
    By ashtaq in forum Troubleshooting / "How do I..." Questions
    Last Post: 06-05-2005, 01:26 AM
  3. [HACK] redirect news reply to portal and scroll to original news thread...
    By jfreels in forum Add-On Modules & Modifications
    Last Post: 02-09-2005, 06:50 PM
  4. how do i turn off signatures for the portal page?
    By Zejari in forum Troubleshooting / "How do I..." Questions
    Last Post: 02-05-2005, 06:40 PM
  5. News Signatures
    By bspiller in forum Troubleshooting / "How do I..." Questions
    Last Post: 01-11-2005, 04:17 PM
