Results 1 to 5 of 5
Thread: News module displaying threads to admin only
    Default News module displaying threads to admin only
    Hi guys,
    I've got what possibly might be a problem with the way i've set things up but after i recently upgraded vBa my news module stopped working but only for regsitered users, was displaying the threads for guests, admins and any other usergroup but registered.
    I've tried messing with the permissions for the relevant forums and i've listed my settings below, can someone just confirm that these are right.
    Category where news threads are kept has these permissions set:
    Can view forum - No
    Can view thread content - Yes
    Can view others threads - Yes
    Rest are set as no
    settings for the news module
    Maximum threads to display = 10
    Cut-off = 0
    Max characters = 0
    Enable attachments = all
    Apply forum permissions = yes (also tried no)
    send to friend=yes
    attach tag=no
    Allowing html, bb and img
    Is that right or am i missing something, I also should mention that i recently installed VbSEO and this problem was apparent after that, but i've tried disabling that and renaming htaccess just to verify that that isnt causing it.
    Cheers
    Tom
    Default Re: News module displaying threads to admin only
    If I'm thinking correctly, the "Can view forum" setting also needs to be enabled.
    That's cured the problem, cheers Brian
    With that in mind, how would i then set it so that the forum is viewable only to admins from the forum but not vBa as i was planning to hide the actual forum from public viewing and use it for like a site news thing
    After thinking about it, the 'Can view forum' permission really shouldn't be the one that's used to check permissions anyways. If you'll look in your includes/vba_cmps_include_bottom.php file for this code:
    $vbulletin->bf_ugp_forumpermissions['canview'
    $vbulletin->bf_ugp_forumpermissions['canviewthreads'
    Then that will cause the program to check the 'Can view thread content' permission instead, and allow you to set your permissions back the way you had them and block other groups from seeing that forum(s). Note that this change will also be applied in the next release.
    That's sorted it, thanks Brian
    Put the can view permissions back to no for everyone other than admin and it still displays as expected for visitors
  1. Recent threads not displaying posts from sub-sub-forums
    By AyeCapn in forum "How Do I..." Questions
    Last Post: 05-18-2007, 12:32 PM
  2. News Module - Remove Threads removes ALL Threads
    By kall in forum Troubleshooting & Problems
    Last Post: 10-08-2006, 05:09 PM
  3. News Module Displaying on Forum page
    By DanGarion in forum Troubleshooting & Problems
    Last Post: 07-22-2006, 04:48 PM
  4. News Module displaying Announcements
    By 87accordlxi in forum Module & Modification Discussion & Requests
    Last Post: 03-31-2006, 12:11 PM
  5. Displaying threads/posts within vBa?
    By Rukas in forum "How Do I..." Questions
    Last Post: 10-06-2005, 12:22 PM
