Results 1 to 10 of 10
Thread: What counts as a duplicate link?
    Default What counts as a duplicate link?
    I currently have Allow Duplicate Links set to No. However, it won't allow completely different links from the same site to be added. Will it only allow one link per domain?
    Default Re: What counts as a duplicate link?
    Yes, it checks the links by domain. Otherwise people could easily get around that by adding links like this:
    http://www.vbadvanced.com
    http://www.vbadvanced.com/index.php
    We need to get around this issue. What about the Geocities or Yahoo Groups situation? If the above is true, the member's links would be considered duplicates. We also have a domain name that issues out space for users as subdirectories and these users would like to be linked to.
    Better to make the option for EXACT duplicates.
    Please help.
    So, for example, if we wanted to have links to the vbadvanced page and the vblinks page and the vbdynamics page, we couldn't do it? At least not with Allow Duplicate Links set to No?
    Miami
    1,040
    Quote Originally Posted by oldengine View Post
    Please help.
    My way around it is to set a category where I allow for duplicates with all subcategories too. Then in includes/functions_vba_links_savelinks.php I put
    // Missing default fields
    $lcatid=$link['catid'];
    $getparent= $db->query_read("SELECT parentlist from new_adv_links_categories where catid='$lcatid'");
    while ($theparent=$db->fetch_array($getparent))
    $parentlist=explode(',',$theparent['parentlist']);
    if ($_POST['do'] != 'addlink' AND !$link['name'])
    eval('$errors[] = "' . fetch_error('adv_links_missingfiled') . '";');
    else if (in_array("2",$parentlist))
    if ($link['linkurl'] == 'http://' OR !$link['linkurl'] OR ($_POST['do'] != 'addlink' AND (!$link['name'] OR !$link['description'])))
    so for that specific parent catego (2 in my case), you can put as many dupes as you want. Since I am doing this for a yellow pages to allow entry with no links, i just don't check for dupes. And that goes for 600 subcategos under parent number 2
    Lionel,
    Thank you for responding. I'm going to have to figure this out so that all of the categories on my links board can deal with this situation.
    With places like myspace.com and youtube.com surely someone else needs to provide multiple links at the sub-folder level in a domain, yet keep duplicates at that level under control.
    Quote Originally Posted by Doug Nelson View Post
    Can we please take this thread back to the original question?
    I have done a search on this board for "duplicate links" and it appears that there are a lot of users with this issue. However, dealing with it in only ONE category isn't an answer.
    The only solution at this time is to simply ALLOW duplicate links. Hopefully, someone will come up with a method to check the entire link rather than just the domain name for duplicates. So what if someone puts their index.htm or index.html in a couple of times. That's better than having the same page in a dozen times. IT's the DIFFERENT PAGES that we want to allow.
    Can this code be made a bit less aggressive when checking for duplicates so that http://namedomainname.com/myfolder/ and http://namedomainname.com/hisfolder/ are OK, but if either one of them is entered twice, they are rejected?
    http://www.vbadvanced.com/forum/showthread.php?t=23879
    Look in your forum/includes/functions_vba_links_savelink.php file for this code:
            $finddomain strip_url($urlparsed['host']);
    $checkdupe $db->query_read("SELECT linkid, linkurl, valid FROM " TABLE_PREFIX "adv_links WHERE linkurl LIKE '%$finddomain%' " iif(!$dupe"AND linkid != '$link[linkid]'") . " LIMIT 1");
            while (
    $dupe $db->fetch_array($checkdupe))
    $dupe['urlparsed'] = @parse_url($dupe['linkurl']);
    $dupe['linkurl'] = strip_url($dupe['urlparsed']['host']);
                if (
    $dupe['linkurl'] == $finddomain)
    $errors[] = fetch_error('adv_links_duplicate'htmlspecialchars($link['linkurl']), iif($dupe['valid'], fetch_error('adv_links_duplicate_viewlink'$dupe['linkid']), ''));
    Replace with this:
            $dupe $db->query_first("SELECT linkid, linkurl, valid FROM " TABLE_PREFIX "adv_links WHERE linkurl = '" $db->escape_string($link['linkurl']) . "' " iif(!$dupe"AND linkid != '$link[linkid]'"));
            if (
    $dupe['linkid'])
    And that will only return an error if the exact link is found.
    Thank you Brian, I'll get to work on it.
    This is truly appreciated and it's icing on the cake of an EXCELLENT program!
    Please pardon my mess of having asked about this on other categories.
    EDIT: And it WORKS excellently!
    I found my way back here after upgrading to vB 3.7 and putting in the new Links upgrade.
    This mod is definitely an asset!
    Thanks.
  1. Guest book counts
    By attroll in forum Feedback & Suggestions
    Last Post: 07-24-2007, 01:26 PM
  2. duplicate vBA link in adminCP
    By vbusers11 in forum Troubleshooting / "How do I..." Questions
    Last Post: 01-30-2005, 10:49 PM
  3. [MOD] A slightly more helpful duplicate link message
    By StewardManscat in forum Modifications
    Last Post: 01-27-2005, 10:15 AM
  4. View counts not updating
    By Merjawy in forum Site Feedback & Updates
    Last Post: 07-07-2004, 03:53 AM
