Page 1 of 9 1234 ... LastLast
Results 1 to 20 of 179
Thread: VB Blogs Module
    Nov 2004
    15
    Default VB Blogs Module
    It's been a while since I have done anything for vbadvanced so if you guys have a better way, feel free to use this code to get started. This will display the last 5 blogs and who posted them.
    Default Re: VB Blogs Module
    Looks great!
    I will install it and use it for sure.
    Jun 2005
    Raleigh, N.C.
    236
    Nov 2004
    15
    Quote Originally Posted by RaceJunkie View Post
    Sure, hopefully this one will work for you
    Jun 2005
    Raleigh, N.C.
    236
    Quote Originally Posted by ericgtr View Post
    LOL.. Works great, and thanks for your help on .org
    Nov 2004
    15
    BTW if you want a smaller font you can replace the entire contents of the adv_portal_vb_blogs template with this:
    			<td class="smallfont"</td>$spitblogs</td><br />
    I guess i need Blog installed to run this mod.....??
    22
    Black poet. yes, you will need the blog package.
    My forum is located in a subdirectory while vbadvanced is located in the public_html directory. When I select a link on vbadvanced it gives me a 404, page not found error. It is trying to find blog.php in the public directory. where can I edit the path to blog.php to correct this.
    Thanks for the mod. It works fine other than this small problem.
    Nov 2004
    15
    You can change that in the Module settings. Admin CP > vBa CMPS > Edit Modules > [vb_blogs] scroll down and find Module Link.
    Aug 2004
    169
    Thanks for this.
    PS. The default file is blog.php for the header link, not blogs.php.
    Nov 2004
    15
    Quote Originally Posted by indie View Post
    Thanks for this.
    Thanks for pointing that out, I've updated the module.
    Aug 2004
    169
    Problem. It's showing private/hidden blogs in the titles, it's okay when you click though, you get a no permission message. Can you fix that?
    I could not get the module to load, database errors
    Thanks!!
    But Your original file has some error.
    Then, I created new module from your source.
    Thanks.
    Something like this would be much cleaner:
    	<td class="$bgclass">
    		<span class="smallfont">$spitblogs</span><br />
    Anyone know how to get the 'Blogs' link to show up on the Vbadvanced home page?
    Quote Originally Posted by Joe Blow View Post
    Sorry, I should have been more specific. I'm not currently using this addon module (am thinking about it) but have just installed Vb Blogs and the 'Blogs' link in the navbar shows up everywhere except on the Vbadvanced front page.
    Can anyone help?
    Aug 2004
    169
    Can anyone help?
    Wrong thread, but in the CMPS setting Portal Output Global Variables put template_hook.
    Aug 2004
    169
    This mod shows deleted blogs.
    Aug 2004
    169
    Since it shows private and deleted blog entries, I'm removing. Hope it can be fixed.
  1. vBulletin Blogs versus vBadvanced Dynamics
    By Kaelon in forum Pre-Sale Questions
    Last Post: 08-12-2007, 05:24 PM
  2. Collapse and Expand on Blogs
    By attroll in forum Feedback & Suggestions
    Last Post: 05-21-2007, 06:10 PM
  3. vBulletin Blogs coming
    Last Post: 03-25-2007, 03:55 PM
