Page 2 of 33 FirstFirst 1234512 ... LastLast
Results 21 to 40 of 646
Thread: [Module] Customizable RSS feed module
  1. #21
    Feb 2006
    11
    Default Re: [Module] Customizable RSS feed module
    Tried to install but then I get
    Fatal error: file_put_contents cannot write in file. in /modules/rss_cmps_curl.php on line 125
    on the page
  2. #22
    Quote Originally Posted by The Cronic View Post
    on the page
    It means you don't have write permissions for the cache directory.
    Please make sure that you have done a chmod 777 on the cache directory (or whatever value is needed by your specific host.)
  3. #23
    Feb 2006
    11
    I made a directory and called it Cache and set the permissions to 777 before I posted and got that. I must be missing something.
  4. #24
    If you are sure everything is correct then it may be a permissions issue for which you will need to contact your host. A while back I found I needed to change my permissions from 777 to 755 - it had to do with security on the host side of things.
    If you'd like me to look at things just to make sure the module is configured correctly feel free to PM me the login info.
  5. #25
    Oct 2007
    103
    I'm getting the same error.
    Fatal error: file_put_contents cannot write in file. in \modules\rss_cmps_curl.php on line 125
    I checked with my host, and they said that both the cache directory that I created and the modules/rss_cmps_curl.php file are set as 777.
    Quick question, how is the RSS Cache Directory supposed to be entered in the admin panel? I couldn't find any info or examples on it.
    In my FTP, my forums are installed in the httpdocs folder. So, the rss file is located in "httpdocs/modules/rss_cmps_curl.php". I created a folder "httpdocs/rsscache" and set these permissions to 777. In the admin panel for the RSS Feed module, I tried adding the directory many different ways:
    "/rsscache"
    "/rsscache/"
    "\rsscache"
    "\rsscache\"
    Something strange is going on because not only do none of these configurations work, but if I just add "\ThisIsNotARealFolder\" I get the same error... Shouldn't I get a "folder not found" error or something along those lines?
    Since this is a module contained in the "modules" folder under the root directory, since my rsscache folder is in the root directory (above the modules folder) do I need to do the whole "../" to tell the module to look for a folder called "rsscache" above the current folder?
    EDIT: Sorry, I guess I was originally mistaken. The rsscache folder wasn't completely set at 777. Now it is Thanks, everything works great now!
    EDIT #2: I found out that you do need to enter the folder as "rsscache" (no slashes)
  6. #26
    Oct 2007
    22
    Great mod. Thanks!
    But the news seem to be UTF-8 encrypted. Ist there any way to change encryption to latin-7. see screenshot...
  7. #27
    There are instruction on dealing with conversions in the 3.5.x version of the module. I don't have time to look it up at the moment but it involves the use of the iconv() function.
  8. #28
    I keep getting this error:
  9. #29
    Quote Originally Posted by Ranger375 View Post
    That means that you don't have the right permissions set up for the cache folder or that the path to the folder isn't specified correctly. Look a few posts up as another person just ran into the same situation and have the path specified incorrectly.
  10. #30
    I checked w/ my host, and they confirmed its set at 777.
    The error message can be viewed here: http://shadowspear.com/vb/cmps_index.php
    Folder location: http://shadowspear.com/vb/modules/rsscache
    Anything else I could be doing wrong?
  11. #31
    If that's what you are using for the path then that's the problem. The path will be similar to what you use th vBa (i.e. /home/mystuff/vb/modules/rsscache).
  12. #32
    whats the recommended method for determining the path?
  13. #33
    ahhh nm i got it. Thanks for the help
  14. #34
    Oct 2007
    Is there a way I can use the advanced options or templates to strip images from within a feed? I'm having an issue with wide images breaking tables in a non-fluid theme.
    Cheers!
  15. #35
    Quote Originally Posted by KittyKatze View Post
    Cheers!
    Yes. You can use the Data modification section to add code to strip out <img> tags if you wish. It's a bit tricky but not impossible so long as you are competent at manipulating strings using php.
  16. #36
    May 2007
    France
    11
    hello !
    thx for this modules !
    But I have this error :
    Warningfile_put_contents(/cacherss/www.feediz.com-synd-56.xml.cache) [function.file-put-contents]: failed to open streamNo such file or directory in /modules/rss_cmps_curl.php on line 181
    What is the problem
  17. #37
    Quote Originally Posted by kaleu View Post
    hello !
    What is the problem
    It more than likely means that the permissions are not set correctly for the cache folder. Remember, the folder needs to be set to 777.
  18. #38
    May 2007
    France
    11
    my "cacherss" folder is in Chmod 777 ...
  19. #39
    If yo are sure that the folder has the correct permissions then about the only other thing it can be is that there's a problem with how you specified the path in the module setup. If it's not pointing to the correct place then that error will still appear.
    I'm guessing that your cache folder isn't really located on the root of the server (/cacherss/...) as indicated in the error message.
  20. #40
    May 2007
    France
    11
    My folder location : http://www.bezak.fr/forum/modules/cacherss
    So the RSS Cache Directory is : /forum/modules/cacherss ??
  1. [Module] Customizable RSS feed module
    By Tom M in forum Add-On Modules (version 3.x & 2.x)
    Last Post: 02-13-2014, 08:05 AM
  2. vBa CMPS: Customizable RSS feed module
    By Tom M in forum Add-On Modules & Modifications
    Last Post: 05-30-2006, 12:31 AM
  3. RSS feed module for VBA 2 and VB3.5
    By rsailors in forum Modifications (version 3.x & 2.x)
    Last Post: 03-25-2006, 10:18 PM
  4. [REQ] RSS feed module
    By rgourley in forum Module & Modification Discussion & Requests
    Last Post: 10-21-2005, 11:55 PM
  5. User customizable CMPS page
    By ogetbilo in forum Feedback & Suggestions
    Last Post: 05-20-2004, 12:04 PM
