Page 3 of 33 FirstFirst 12345613 ... LastLast
Results 41 to 60 of 646
Thread: [Module] Customizable RSS feed module
  1. #41
    Default Re: [Module] Customizable RSS feed module
    Quote Originally Posted by kaleu View Post
    My folder location : http://www.bezak.fr/forum/modules/cacherss
    So the RSS Cache Directory is : /forum/modules/cacherss ??
    If the cacherss folder is within the modules folder then it will probably be the similar to your cmps index path with the '/modules/cacherss' tacked onto the end.
  2. #42
    Oct 2007
    16
    It's too bad that this module works some times, but not others. It was working fine for a couple hours but then stopped and I started getting the:
    Fatal error: file_put_contents cannot write in file. in /modules/rss_cmps_curl.php on line 125
    I need something dependable so I will have to keep looking.
  3. #43
    Quote Originally Posted by SFDonovan View Post
    The fact that it is unable to write to your file system is a problem either with your permissions or the path hasn't been set correctly. The only other possibility is that your host is doing something to prevent it from writing. Myself and many others have been using this module for a number of years w/o any issues so I'm fairly confident the problem you are encountering, though reported by the module, isn't a problem that's caused by the module.
    No matter though. About the only other module I know of makes use of Carp (you'll need to install that) to work. Do a search here and you should be able to locate it.
  4. #44
    Oct 2007
    16
    The path I have is correct and the permissions are 777. I don't know what else to do. The host says it should work, as he is not blocking anything.
    At one point is was working but then stopped, and I got the error. Later I tried again and it worked for a couple hours but again it stopped and the error came back.
    *shrugs*
    It is probably just what I'm looking for but for some reason it is behaving oddly.
  5. #45
    If you want to pm me login info I'll be happy to take a look at things.
  6. #46
    May 2007
    France
    11
    Quote Originally Posted by Tom M View Post
    ok ! I've found the solution !
    thx for your help !
  7. #47
    May 2007
    France
    11
    I've another problem ...
    I'm using french RSS fieds and the letters like é, è, à appears like that : é or è
    Is there a solution to correct that ?
  8. #48
    You can try looking here to see if that helps. Your host will need to support the iconv() capability. You'll also need to choose the correct character set for the conversion.
  9. #49
    May 2007
    France
    11
    ok it works perfect !
    thx you very much !!
  10. #50
    Oct 2007
    16
    Here is a path.php file you can use to find out the path to the rsscache folder you create.
    Copy this to a file and save, then upload to your rsscache folder on your webserver.
    <?php
    if ($_SERVER['PATH_TRANSLATED'])
    $path $_SERVER['PATH_TRANSLATED'];
    else if (
    $_SERVER['SCRIPT_FILENAME'])
    $path $_SERVER['SCRIPT_FILENAME'];
    else
        echo
    'We are sorry, but this script is unable to determine your forums path.';
        exit;
    echo
    substr($path0, (strlen($path) - 14));
    Then go to that url and see what is displayed.
    If you placed the folder in the root (public_html) --> http://www.mywebsite.com/rsscache/path.php
    If you placed it in your modules --> http://www.mywebsite.com/forums/modu...cache/path.php
  11. #51
    Oct 2007
    21
    is there anyway to use this with a server that has curl disabled? ie integrating the code from the previous version of the module?
  12. #52
    Quote Originally Posted by papokergod View Post
    Yes, you can grab the 3.5 version and copy the code from that and replace the curl stuff. Interesting, most host seem to moving towards curl and not allowing access via the older method.
  13. #53
    Oct 2007
    21
    ok gonna need help with that part as I am sure this is not gonna be the only time this happens, by the way everything loaded right the problem was with the module loaded for the page it would only come up with a blank white page. which led me to here. I saw that you mentioned to someone about checking for curl support. so I checked that has to be my problem.
    thanks again for your help in advance.
  14. #54
    Oct 2007
    21
    ok so far I am coming up with these edits:
    find:
    s:17:"rss_cmps_curl.php"
    replace with:
    s:17:"rss_cmps2.php"
    the find and remove:
     else
                    {        // get the remote feed
                            $curl_handle = curl_init($file);
                            curl_setopt($curl_handle, CURLOPT_RETURNTRANSFER, 1);
                            curl_setopt($curl_handle, CURLOPT_CONNECTTIMEOUT, 2);
                            curl_setopt($curl_handle, CURLOPT_HEADER, false);
                            // fetch the remote feed
                            $file = curl_exec($curl_handle);
                            curl_close($curl_handle);
                            unset($curl_handle);
                            return !$file ? false : $file;
    find:
    if(!function_exists('rss_get_contents'))
            function rss_get_contents($file)
    replace with:
    if(!function_exists('file_get_contents'))
    find:
    replace with:
    function file_get_contents($file)
    find:
    $rssdata = rss_get_contents($rss_feed);
    replace with:
    $rssdata = file_get_contents($rss_feed);
    find:
    replace with:
  15. #55
    You really can't edit the .module file. The way to do what you want is to install the curl version and then edit the php file. You can copy the code from the old module file and then paste it into the php file. Hope that makes sense. There's no real need to rename the php file unless you want to.
  16. #56
    Oct 2007
    21
    ok still confused what to edit in the php file I tried to cut and paste the entire code from the old rss_cmps.php to the rss_cmps_curl.php and still does not work. is that right and do I have another problem to deal with or?
  17. #57
    Oct 2007
    103
    Hi,
    At one point I had this module working pretty good. It would cause the page to hang at times, but it would still work. BTW, is there a limit to how many of these modules I can use on a single page? I had around 10 or so.
    Now I'm getting a blank page though. The only thing that I did was removed the default site navigator module (complete uninstall), because I was installing a new one. As soon as I removed the default site navigator module, I got this problem
    It's definitely a problem with this module though, because if I remove all of these RSS modules from my homepage, it works fine. I'm thinking that somehow some code got deleted when I was removing the site navigator, but I don't know how to check that.
  18. #58
    Pretty much all you should need to do is to replace this
    		if (strncmp('http:', strtolower($file), 5) !=  0)
    		{	// fetch the cached file
    			$file = file($file);
    			return !$file ? false : implode('', $file);
    		else
    with this
  19. #59
    Oct 2007
    21
    ok done still not showing up however the blank white page is gone but still the module not showing up. It looks as though its attempting to write to the cache directory, but its not writing anything to the cache file. meaning writing a 0kb cache file (blank) so naturally the module wont show up in the index page nor the preview window.
    the cache file it creats is chmod 666 is that right? the cache folder itself has already been chmodded 777. both of these have been tested using the ftp client.
    I am wondering if its the same problem that that other guy had and he had to make up a script to chmod the cache directory usng the php script?
    this is what the template looks like now. Have not renamed just edited it.
    if(!function_exists('file_put_contents'))
    	function file_put_contents($filename, $data, $file_append = false)
    		$fp = @fopen($filename, (!$file_append ? 'w+' : 'a+'));
    		if(!$fp)
    			trigger_error('file_put_contents cannot write in file.', E_USER_ERROR);
    			return;
    		fputs($fp, $data);
    		fclose($fp);
    // Set up the key paramters before we get underway
    // location of the rss live feed
    $rss_feed = $mod_options['portal_rss_feed'];
  20. #60
    If you aren't getting any errors and the file is empty then it's possible it's a permission problem, though if the folder is really 777 then a file permission of 644 or 666 should be OK.
    What's the url of the feed you are trying to use?
    Do you have a link to your page? Custom style?
  1. [Module] Customizable RSS feed module
    By Tom M in forum Add-On Modules (version 3.x & 2.x)
    Last Post: 02-13-2014, 08:05 AM
  2. vBa CMPS: Customizable RSS feed module
    By Tom M in forum Add-On Modules & Modifications
    Last Post: 05-30-2006, 12:31 AM
  3. RSS feed module for VBA 2 and VB3.5
    By rsailors in forum Modifications (version 3.x & 2.x)
    Last Post: 03-25-2006, 10:18 PM
  4. [REQ] RSS feed module
    By rgourley in forum Module & Modification Discussion & Requests
    Last Post: 10-21-2005, 11:55 PM
  5. User customizable CMPS page
    By ogetbilo in forum Feedback & Suggestions
    Last Post: 05-20-2004, 12:04 PM
