Thread: [RC2] Integration not saving page association settings
    Default [RC2] Integration not saving page association settings
    I have two CMPS page named "vBa Links" and "vBGallery" both configured as Module pages.
    I have "links_index" associated to the "vBa Links" page and "gallery_index" associated to the "vBGallery" page using the THIS_SCRIPT integration method.
    When I save the settings each association is correct during the "Select the CMPS page that you would like to integrate..." confirmation page has the correct associations.
    When I visit the vBa Links index page the modules on the "vBa Links" CMPS page are displaying the correct ones. I can't verify the gallery settings because integrating vBGallery using the THIS_SCRIPT method isn't working (still trying to figure that one out; others are having the same problem).
    The problem is that when I then go back into the CMPS integration settings page both "links_index" and "gallery_index" are showing as being associated to the "vBGallery" CMPS page.
    The other ticket is still open.
    Default Re: [RC2] Integration not saving page association settings
    Looks like there's a small issue where (obviously) it's not selecting the correct page. If you'll open your includes/vba_cmps_adminfunctions.php file, look for this code:
            if (!$selectopts)
    $selectopts print_integration_page_select($intpage'name'$vbphrase['remove'], $exclude);
    Then that should take care of the problem.
            if (!$selectopts)
    That seems to take care of it, thanks.
    This resolved my issue as well, Thanks!
  1. Integration settings within admincp
    By motowebmaster in forum Troubleshooting & Problems
    Last Post: 09-26-2007, 01:18 PM
  2. module settings not saving
    By WAR in forum Troubleshooting & Problems
    Last Post: 06-20-2007, 12:53 PM
  3. vba links 2.0 beta2 saving settings
    By jluerken in forum Bugs From 2.0 Beta 2
    Last Post: 10-17-2006, 11:57 PM
  4. Saving module collapse settings per user?
    By trana in forum Troubleshooting & Problems
    Last Post: 05-26-2006, 08:26 PM
  5. After saving changes, blank page occurs
    By brando in forum Troubleshooting & Problems
    Last Post: 08-21-2005, 05:31 PM
