Results 1 to 20 of 40
Thread: Filter News Module by Thread Prefix
    Nov 2005
    127
    Default Filter News Module by Thread Prefix
    Is it possible to have the news module filter the threads it retrives by thread prefix? IE, if I have the news module gather news from several catagories and I only want it to get the threads with an "official" prefix, is this possible?
    Default Re: Filter News Module by Thread Prefix
    I'm assuming you're using vB 3.7 for your thread prefixes? If so, you should be able to look in your modules/news.php file for this line:
    WHERE thread.threadid IN(" . implode(',', $newstids) . "
    WHERE thread.threadid IN(" . implode(',', $newstids) . ") AND thread.prefixid 'X'
    Replace the 'X' there with the "Prefix ID" from the prefix you're wanting to use and that should do the trick.
    Nov 2005
    127
    Damn Nice work.
    Jul 2008
    Hi.
    I've done it with url GET ( ?section=xxxxxx )
    Nice
    Quote Originally Posted by PiTXI View Post
    Hi.
    Nice
    Can you explain how you have gotten that done?
    Mar 2007
    Hi,
    I can't get this to work correctly, only one thread is shown and the date is set to 0.
    I copy the news.php module and save as a new file called news2.php
    Then copy New Topics and selected to use news2.php.
    What am I doing wrong?
    What about for vb 3.8? Would it be the same fix? If I can do this I'll be able to delete 50+ forums on my site by merging with some others.
    Quote Originally Posted by lukem View Post
    I tested it out and yes, it works on vb 3.8 perfectly. This is a very cool feature, maybe you should add it to the options in a future release. Now I just made a decent amount of reorganization work for myself tonight.
    I'm not sure what is happening but it isn't pulling in ALL the forums with the prefix NEWS that's I've added. I noticed it didn't show any until I posted a few new ones with NEWS as the prefix. I checked my site this morning and it wasn't showing anything. So I added two threads with NEWS and they show up. I have the Cut-Off Date set to 0 so it should be pulling in all forums. Any ideas???
    As soon as I pull out AND thread.prefixid = 'NEWS' all the threads show up from the forums I have selected. I don't get it.
    Checked this morning and it is again listing no threads with the NEWS prefix this morning. It is like it is resetting each data yet I still have 0 in the cutoff. I've tried changing that to something like 120 but it still doesn't work.
    USA Carry - Open and Concealed Carry Information and Community
    Bump for any kind of response from support?
    Sorry, but I'm not sure what to tell you. There shouldn't be any reason it would not pull those threads unless you've modified something else.
    I haven't modified anything else because when I take the prefix code out it pulls in all the forums just fine. And it seems the user nfn had the same problem as me. I'd be willing to pay for someone to fix this if possible because I rearrange my forums based on this working.
    bump looking for help
    bump for some support on this
    Apr 2009
    Question
    I would like to do that with the module Recent Threads. Is it possible??
    You should be able to do that by adding a new plugin to the 'vba_cmps_module_recthreads_start' hook location with the following code:
    $vba_threads_condition .= " AND thread.prefixid = 'X'";
    Replace the 'X' there with the "Prefix ID" from the prefix you'd like to use.
    Apr 2009
    Thanks a lot!
    Works very good.
    All my respect to your work, great job
    greets from switzerland
    Feb 2008
    296
    I have found the problem with this in not displaying the number of news items but unfortunately can not find the answer.
    Adding the thread.prefixid code does work however there are limitations. Say for example:
    1. You have created a prefix say "MyNews"
    2. You have set the records to display by date and descending - which you would normally do for news
    3. You have set "Maximum Number of Threads to Display" to 10
    4. Records 4, 8, 15 and 20 have the prefix of "MyNews"
    You will only see 2 records i.e. 4 and 8 in the display because even though all the other records don't have the prefix of "MyNews" they are still counted in the "Maximum Number of Threads to Display" setting of 10.
    This is a big problem as you can not control the actual number of news items to display and an even bigger problem if you are using the Pagination box.
    Any suggestions on an answer to this
  1. Possibilities of filtering news by THREAD PREFIX
    By JohnBee in forum Module & Modification Discussion & Requests
    Last Post: 09-14-2007, 06:59 AM
  2. Thread title in news module
    By powerful_rogue in forum "How Do I..." Questions
    Last Post: 07-30-2007, 10:28 AM
  3. News Module thread length issue
    By sublimevb in forum "How Do I..." Questions
    Last Post: 08-19-2006, 06:45 AM
  4. News Module - Thread Title Question
    By blkatt in forum Troubleshooting / "How do I..." Questions
    Last Post: 09-20-2005, 06:58 PM
