Results 1 to 8 of 8
Thread: Beta 2 SQL Errors When Deleting & Missing Phrases
    Default Beta 2 SQL Errors When Deleting & Missing Phrases
    Hi Brian,
    When I view the Moderation tab the table on the left appears to have a few misformed rows at the bottom.
    Also, it looks like a phrase might be missing in the table header above "No Links Awaiting Moderation"
    Attachment 4440
    There is a missing phrase in the Admin Options in the Links Options drop down.
    Attachment 4441
    When a new link is added, the email notice is missing details:
    Hello,
    Cliff has just submitted a new link in the Blood Donor Centers category. You may view the link here:
    http://www.bloodbanktalk.com/links/
    Here are the details for that link:
    Name:
    URL:
    Description:
    User: Cliff
    I deleted a link and get a database error. The link listed below isn't the one I was trying to delete. Then when I go back to the index page, it's still listed as the most recent link, but when I view the category, it's not there. I ran the maintenance scripts and that seemed to help.
    Database error in vBulletin 3.7.0:
       UPDATE vB36_adv_links_categories SET
        linkcount = linkcount - 1,
        lastlinkid = '42',
        lastlinktitle = 'HCLL Users Group',
        lastlinkuserid = '321',
        lastlinkusername = 'CLIMBER514',
        lastlinkdateline = '1162319028'
       WHERE catid = 2;
    MySQL Error   : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '
        lastlinkid = '42',
        lastlinku' at line 4
    Error Number  : 1064
    Request Date  : Friday, May 30th 2008 @ 12:46:32 PM
    Error Date    : Friday, May 30th 2008 @ 12:46:34 PM
    Script        : http://www.bloodbanktalk.com/links/moderate.php
    Referrer      : http://www.bloodbanktalk.com/links/a...=editlink&l=72
    IP Address    : xxx.xxx.x.x
    Username      : xxxxx
    Classname     : xx_xxxxxxxx
    MySQL Version : 5.0.54-log
    Jul 2005
    120
    Default Re: Beta 2 errors
    I think I have the same problem - besides that I am only able to see the 'delete link' phrase (image 1)
    Default Re: Beta 2 SQL Errors When Deleting & Missing Phrases
    Thank you for pointing these things out. I've applied the fix to the download package here, so if you will download the files again, replace your links/moderate.php and forum/admincp/vbalinks_install.php files with the updated versions, then run this query via phpMyAdmin or your Admin CP:
    UPDATE phrasetype SET fieldname = 'adv_links_moderate' WHERE fieldname = 'adv_links_moderation';
    After running the query, go to the admincp/vbalinks_install.php file in your browser, select the option there to re-install your phrases, and that should take care of these issues.
    Jul 2005
    120
    Sorry didn't solve the problem for me
    Firstly I tried to reupload the files you mentioned. Then the whole package. Both times the SQl gave the same result:
    #1146 - Table 'login_servername_forums.phrasetype' doesn't exist
    I tried both with PHPadmin and in the admin panel. After that I tried to reinstall phrases without luck - then, just to try - settings and templates.
    Nov 2006
    Italy
    37
    I had the same problems and this fix has resolved the issue for me.
    Thanks Brian.
    Jul 2005
    120
    I have submitted a ticket with login details. I guess it is some little mistake as everything else seems to work.
    Seems fixed, thanks.
    Jul 2005
    120
    Brian just solved my issue - and now it works! For everybody else. I use a prefix and then the sql should be:
    UPDATE table_prefixphrasetype SET fieldname = 'adv_links_moderate' WHERE fieldname = 'adv_links_moderation'
    Thank you to Brian for his super fast and efficient support!
  1. Hep! Missing phrases
    By etaslim in forum Troubleshooting & Problems
    Last Post: 07-20-2007, 12:38 PM
  2. Errors and Missing Images
    By bushka in forum Troubleshooting & Problems
    Last Post: 02-19-2006, 08:34 AM
  3. Deleting 3.5.x???
    By Wedge in forum "How Do I..." Questions
    Last Post: 02-02-2006, 02:37 AM
  4. Phrases / Text missing
    By sapper6fd in forum Troubleshooting & Problems
    Last Post: 01-15-2006, 11:52 PM
  5. Missing phrases
    By orca in forum Bugs From 1.0 RC1
    Last Post: 12-24-2005, 03:41 AM
