Results 1 to 9 of 9
Thread: Thumbshots issue
    Miami
    1,040
    Default Thumbshots issue
    There is something going on with displaying thumbshots.
    It's enabled, I tried removing the if condition in the linkbit template to bypass it, no matter what it will not display. I put the code simplified
    <img src="http://open.thumbshots.org/image.aspx?url=$link[linkurl]">
    then it displays
    Real useful and Cool vBulletin addons
    Miami
    1,040
    Default Re: Thumbshots issue
    hummmmm I removed
    width="120" height="90"
    from template and it displays.... weird
    Miami
    1,040
    Definitely does not like both parameters. Removing
    height="90"
    will display it. This is happening in both FF and IE. I just took a look at their site and the code is
    <img src="http://open.thumbshots.org/image.aspx?url=[LINK]" border="1" />
    I think the 120x90 should be defined in the class <td class="$show[class_thumbshot]"> in case it tries to display the 1px image for those with no DMOZ listing. (where to define that class by the way?)
    If the thumbshot for the particular URL does not exist or is empty (file not found, connection timeout, invalid request error, etc.) then the thumbshot returned will be a 1 x 1 transparent pixel. If you need to force every thumbshot to fill the 120 x 90 pixel space, you can simply wrap each thumbshot with a borderless table cell of that size.
    They are also mentioning a Symantec issue blocking thumbshots, which is not my case (I had that issue on my own site, where everybody but me could see the banners and that had made had made me disabled ad blocking already), so I thought I'd mention it because some people will experience it.
    Weird... I've seen a number of links with no thumbshot, but didn't have any problems like that...
    It's defined in the files and is just a variable, not a class. It switches between the alt1/2 classes depending on what other options are enabled that would add <td> tags in the linkbits template.
    Miami
    1,040
    I see according to your footer that this option is enabled in your demo.
    Here is a screenshot of what I see with an empty slot for the thumbs.
    Mine was like that until I remove the dimensions tags
    http://www.vbcover.com/links/
    Weird, they show up fine for me in IE and FF... What browser/OS are you using? Guess the height tag will need to go in the next version.
    Miami
    1,040
    I have that problem with both IE 7.0 and FF
    Oct 2009
    i have this problem as well is there a solution?
    http://www.vfxtalk.com/facilities/
    1,694
    Lionel's issue was posted @18months ago and was from Links Directory v.3.0 Beta 2.
    We are now on v 3.2.1 .Viewing your forum I see no problem,the thumbshots are showing correctly.
    Seen vB5 beta? No more vbulletin for me, done , gone,finished .
  1. RSS issue
    By Lionel in forum Bugs From 1.0 RC1
    Last Post: 08-18-2007, 01:30 PM
  2. Still another Nav issue ... sorry
    By Jmistrot in forum Troubleshooting & Problems
    Last Post: 04-26-2007, 12:20 PM
  3. how do i fix my issue? i cant see anything
    By lowandloudinc in forum Troubleshooting / "How do I..." Questions
    Last Post: 02-15-2005, 11:42 PM
  4. Thumbshots.org - Integration
    By interfx in forum Pre-Sale Questions
    Last Post: 11-25-2004, 09:12 AM
  5. Will it be an issue?
    By pulsetoday in forum "How Do I..." Questions
    Last Post: 09-03-2004, 01:49 AM
