Thread: newreply.php possible issue
    Jul 2004
    Nagano, Japan
    Default newreply.php possible issue
    Hi there,
    I just upgraded to the latest beta2 version and am getting the following database error when replying to a link. The installation seemed to go well and everything looks updated so I'm not sure where to look here. The newreply.php is the latest uploaded from the update.
    http://www.ricoche.net/links/
    Thanks! - Jim
    Database error in vBulletin 3.7.0:
    UPDATE adv_links_categories SET
    postcount = postcount + 1
    WHERE catid IN();
    MySQL Error   : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 3
    Error Number  : 1064
    Request Date  : Monday, June 2nd 2008 @ 09:18:08 PM
    Error Date    : Monday, June 2nd 2008 @ 09:18:08 PM
    Script        : http://www.ricoche.net/links/newreply.php
    Referrer      : http://www.ricoche.net/links/newreply.php?l=2
    Classname     : vB_Database
    MySQL Version : 5.0.51a-community
    Jul 2004
    Nagano, Japan
    Default Re: newreply.php possible issue
    I should add that when I reply to a link it actually gets entered into the database, but doesn't seem to get pulled or something along those lines.
    When I physically delete the reply, I get the following error.
    Warning: array_merge() [function.array-merge]: Argument #2 is not an array in /home/ricochen/public_html/links/moderate.php on line 2060
    Warning: Cannot modify header information - headers already sent by (output started at [path]/includes/class_core.php:3237) in /home/ricochen/public_html/links/moderate.php on line 2072
    Thanks for pointing this out. I've updated the download package here to include the fix, so if you will download the files from here again and replace your links/addlink.php file with the updated version, that should take care of the issue.
    Jul 2004
    Nagano, Japan
    Splendid! Thanks Brian.
    Jim
    Jun 2008
    Ottawa
    38
    I redownloaded the package and I'm still getting an error that I was mentionning here.
    TriMe
    Try deleting the links/moderate.php file from your server and then re-upload the one that you just downloaded. If that does not help, please submit a support ticket via the Members' Area here and I'll take a look at things for you.
    Jun 2008
    Ottawa
    38
    Yes I tried what you suggested, still get the error.
    Ill submit a ticket now,
    Thanks Brian
  1. Another issue
    By dcuellar in forum Troubleshooting & Problems
    Last Post: 03-14-2008, 11:13 AM
  2. Still another Nav issue ... sorry
    By Jmistrot in forum Troubleshooting & Problems
    Last Post: 04-26-2007, 12:20 PM
  3. Side modules on SHOWTHREAD, newreply, etc ?
    By mindbuster in forum Troubleshooting & Problems
    Last Post: 11-03-2006, 08:38 PM
  4. New Install~ Screwed up newreply.php
    By Susie_in_Texas in forum Troubleshooting & Problems
    Last Post: 02-09-2006, 08:57 PM
  5. how do i fix my issue? i cant see anything
    By lowandloudinc in forum Troubleshooting / "How do I..." Questions
    Last Post: 02-15-2005, 11:42 PM
