Thread: vBadvanced Global Options dissapear after vBa Links Uninstall
    Default vBadvanced Global Options dissapear after vBa Links Uninstall
    After uninstalling vBa Links, the vBadvanced Global Options dissapear from the vBadvanced CMPS Options menu.
    You can still click the vBadvanced Global Options entry and go to that page. However, the settings do not take effect and the page is missing the titles from each setting.
    Default Re: vBadvanced Global Options dissapear after vBa Links Uninstall
    Thank you for pointing this out. Looks like there is a small bug in the install file that's causing the vBa global phrases to be removed, which I will be sure is corrected in the next release. In the mean time you can use the 'Reinstall the Phrases' option from either the CMPS or Links install file to restore those phrases.
    Nothing besides the phrases is removed, so just the missing phrases would not have an effect on the functionality of that setting.
  1. Is it possible to blow out Global Options?
    By gpc10347 in forum Troubleshooting & Problems
    Last Post: 06-02-2008, 03:01 PM
  2. Missing VbAdvanced Global Options screen
    By jim6763nva in forum Troubleshooting & Problems
    Last Post: 02-20-2008, 12:10 PM
  3. vBadvanced CMPS 2.2.1 won't uninstall
    By gorp in forum Troubleshooting & Problems
    Last Post: 12-21-2006, 10:21 PM
  4. How easy is it to uninstall vBAdvanced?
    By Monolith in forum "How Do I..." Questions
    Last Post: 12-05-2005, 07:21 PM
