Results 1 to 12 of 12
Thread: VBA Links Search on Navbar Search Drop-Down
    Nov 2007
    87
    Default VBA Links Search on Navbar Search Drop-Down
    VBA Links Search on Navbar Search Drop-Down 1.0 Beta
    Description: This adds a VBA Links Search on the Navbar Search Drop-Down.
    Instructions: Follow the steps below.
    1) Go to Manage Products and add the product xml file.
    2) Add "vbalinks_searchform" to Portal Output Global Variables in vBa CMPS settings.
    That's it. You are done!
    PS - Special thanks to Lionel for his help getting this to work.
    Nov 2007
    87
    Default Re: VBA Links Search on Navbar Search Drop-Down
    * Reserved *
    Nov 2007
    87
    Does anyone knows how to expand the VBA Links Search Box so it's the same size as Forum/Blog Search? (see the image in the 1st thread)
    Either add 'width="100"' to your main table there, or remove the <table> and just use the module wrapper template.
    Nov 2007
    87
    I just tried it both the ways you suggested, removing the table and adding width="100", but neither one works for me. The vba links search box stays the same size (smaller than the other boxes).
    I've looked at examples of other search boxes and they don't have a table. I know you are right, yet it still doesn't work for me. I am perplexed. It's got to be simple, but I can't figure out what I'm missing.
    Nov 2007
    87
    It appears that it only happens when I add GTSearch: Google™ Custom Search Engine (which is something I should ask them about). I attached the image below so you can see how it's not sized right.
    If I remove the GT Search, the VBA Links Search shows up fine. I just can't figure out what is different with the Blog and Forums search that allows it to re-size, while the VBA Links Search can not.
    Oh well, it works perfect as long as that GT Search is not installed.
    Aug 2008
    Charlotte, North Carolina
    Thanks very much for the hack, works great YOU ROCK!
    Godspeed Technologies, LLC
    Nov 2007
    87
    Thanks. I appreciate the praise.
    It would appear that this has been implemented already in v3.0 Gold? Can someone confirm?
    Just another squirrel trying to get a nut.
    bodynspirit.net, payinitoff.com, & allthingsmoto.com
    Yes, there is a default setting now that will allow you to display a search box.
    Thanks Brian.
    Jul 2007
    London UK
    30
    Smile Nice Mod
    Nice Mod many thanks went in a treat
    RoyMogg
  1. Replies: 1
    Last Post: 03-17-2008, 01:45 PM
  2. search not directing to forums search on portal
    By hornstar85 in forum Site Feedback & Updates
    Last Post: 08-30-2006, 03:16 AM
  3. Navbar search link fine... but pulldown links aren't...
    By BUZZKILLER in forum Troubleshooting & Problems
    Last Post: 02-06-2006, 05:49 PM
  4. Bug: Broken Search... (When Posts included on Search)
    By mskgr in forum Bugs From 1.0.0
    Last Post: 01-29-2005, 10:22 AM
