Thread: vBA Dynamics Rating Options/Box Revisited
    101
    Talking vBA Dynamics Rating Options/Box Revisited
    Good morning everyone,
    Time for more presents.. :-)
    We have modified the current voting/rating options on Dynamics so that is:
    1. using a very complex rating algorithm
    2. the rating/voting options are displayed very clearly on the top of each article - no need to fiddle with menus and unnecessary options / permissions / already voted / etc
    [rating box idea has been inspired from vb.org voting box style]
    This post addresses the 2nd enhancement - if there is enough interest we can publish 1. as well.
    For this enhancement, the following are the changes:
    - changes the rating options to be presented in a yellow[ish] box at the top of each article/page.
    - removes the 'vb-style' drop-down voting option/'Rate article'
    - hides the rating options from guest users or other groups that are not allowed to vote [I mean.. really]
    - shows the vote[d] value right away as well as the total number of votes and final rating on each page and presents the user from voting again [I mean.. really]
    - the rated value[s] are shown in numbers, not stars [better understanding of the actual value]
    Please check the attached archive for all the required files - instructions are inside as well as below.
    --- CUT HERE ---
    1. Create [if it doesn't exist already] a folder called 'plugins' in the vBulletin main folder [your forum folder, _not_ dynamics!] and copy rating_process.php and set_user_entry_rating.php files into it.
    2. Replace the content of the template of "vBadvanced Dynamics Templates »", ADV_DYNA _SHOWENTRY with the content of the file ADV_DYNA_SHOWENTRY.tpl
    (from VBulletin Admin Control Panel, go to "Styles & Templates", select "Style Manager" and then the "Edit Templates" option)
    -- OR --
    if you have this template modified from the original, compare the contents with the original and make the modifications manually.
    3. Add the following plugins:
    (VBulletin Admin Control Panel => Plugins & Products => Plugin Manager => Add New Plugin)
    3a.
    Product: vBadvanced Dynamics
    Hook Location: vba_dyna_functions_saveentry_rate_entry
    Title: Enhanced Rating Process (modifies the actions on the entry rating)
    Execution Order: 5
    Plugin PHP Code: require_once('./plugins/rating_process.php');
    Plugin Active: Yes
    3b.
    Hook Location: vba_dyna_showentry_start
    Title: Enhanced Set User Rating
    Execution Order: 5
    Plugin PHP Code: require_once('./plugins/set_user_entry_rating.php');
    Plugin Active: Yes
    4. That's all folks! Enjoy.
    --- CUT HERE ---
    Cheers,
    aproape
    359
    101
    Hi there deathemperor,
    Unfortunately I cannot supply a demo however I can attach a sample of how the box looks like - with all the information removed [doesn't look nice but.. hmm - not much of a choice for now].
    Hope it's a bit clearer.. if you or anyone else needs more information or example let me know - thanks!
    Cheers,
    aproape
    Sep 2008
    What does it look like for someone who has already voted? How about to guests?
    Is it possible to move the ".16 (1 Vote)" part to a different area of the SHOW_ENTRY template?
    101
    Hi there trigatch4!
    For someone who voted there is only one box [yellow/configurable] - that shows you the total votes/score and your own vote.
    There is no option to vote again [we thought that's redundant].
    Guests - they have a message similar to 'in order to vote on this article please login/register..'
    Yes, it is possible - just insert those rating variables somewhere else.. where would you like to have them?
    Cheers,
    aproape
    thank you but i get this error after ...
    How can i solve the problem ?
    Thanks for this! Installed and it works great!
  1. Replies: 3
    Last Post: 06-30-2008, 08:30 PM
  2. Replies: 3
    Last Post: 02-07-2008, 01:33 PM
  3. Replies: 2
    Last Post: 08-14-2007, 01:49 PM
  4. Order By Rating
    By Grae in forum Bugs From 2.0.1
    Last Post: 03-09-2007, 11:03 AM
  5. Replies: 2
    Last Post: 02-27-2006, 10:48 PM
