Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: vBSEO Sitemap Addon
    101
    Smile vBSEO Sitemap Addon
    Good morning everyone!
    OK - today is going to be a good day in Dynamics' history I think! ;-)
    Two more addons for it.. so let's start with the first one:
    vBSEO Sitemap addon!
    This code requires that vBSEO is already installed and working properly AND that vBSEO Sitemap is installed and working properly [generating regular sitemaps] already.
    What this addon does: it adds the Dynamics URLs for all categories and articles in the system to the vBSEO Sitemap [after the forums URLs].
    The URLs used are preserved as the ones from Dynamics [SEO friendly].
    Default weight is 1.0 for categories and 0.5 for articles. Default frequency is daily for categories and weekly for articles.
    Installation:
    Step 1: Extract from .zip and copy the attached file to /forums_directory/vbseo_sitemap/addons/ directory.
    Step 2: IMPORTANT: Edit this file to specify the location of your Dynamics installation [domain name + dynamics directory]
    Step 3: Enter the filename of the module [vbseo_sm_dynamics.php] into the [Addon Generator Modules] section of vBSEO Sitemap Settings from AdminCP.
    Step 4: Re-generate the sitemap using the vBSEO Sitemap Reports link or wait for it to be re-generated..
    Step 5: OPTIONAL: edit the values for frequency and importance from this module's .php file [weight is given 1.0 for categories and 0.5 for individual articles - with daily for categories and weekly for articles]. Change those if you want to better suit them to your needs.
    Enjoy! :-)
    Cheers,
    aproape
    P.S. Thanks for deathemperor for the initial sharing of his code which we adapted to use the Dynamics SEO URLs.
    101
    Good morning everyone again!
    One more detail - I guess for multiple instances of Dynamics you can just copy this addon with a new name like vbseo_sm_dynamics_02.php and add it just as a second addon to vBSEO Sitemap settings.. [and modify the directory and table names inside the file of course].
    I don't have multiple Dynamics instances to test.. if anyone else [Larina? :-)] has other ideas/input - feel free to contribute!
    Cheers,
    aproape
    Mar 2008
    367
    Hi aproape,
    one day I will ask you, if you will marry me
    Boah, I am so happy about this addon!!! Thank you!!
    I am having a problem and don't know why ...
    In all URLs shown in the sitemap, the category-part is missing.
    So for all my dynamics categories I have one same link like that:
    http://www.domain.com/dynamics/
    Somehow for links to entries the entries names are included into the link, but the category part still misses. So links to entries do look like that:
    http://www.domain.com/dynamics/entry1.html
    (it should look like that: http://www.domain.com/dynamics/category1/entry1.html)
    Do you have an idea, how this can happen? I changed the table name of categories to the one I use, is there something else to change?
    larina
    Last edited by larina; 09-15-2008 at 07:29 PM. Reason: sorry, there was a mistake in the links, now it is right
    101
    Hi there Larina!
    Quote Originally Posted by larina View Post
    Hi aproape,
    Just let me know when so I won't choke or blink too fast!:-)
    Hmm.
    Do you have access to the DB directly?
    Can you run this query from the addon:
    SELECT * FROM " . TABLE_PREFIX . "adv_dyna_categories;
    [replacing the TABLE_PREFIX and the "adv_dyna_categories" table with the one[s] you use?]
    Sounds to me like this query returns empty.. for some reason..
    Let me know if you can run that - thanks!
    Cheers,
    aproape
    Mar 2008
    367
    Hi aproape,
    yes, I can run this query and it does function.
    Hmm, I compared to the old sitemap dynamics plugin, and the query is the same. In the old plugin it was working.
    larina
    Mar 2008
    367
    I think it finds all the categories, as there are many links like that:
    (should be as much as I have categories).
    In the old Plugin (without SEO-links) I used this line to call the categories:
    $lnkg = $db->query_read("SELECT * FROM " . TABLE_PREFIX . "rezepte_categories WHERE active = 1");
    This does work.
    In your Plugin I use this line:
    $cats = $db->query_read("SELECT * FROM " . TABLE_PREFIX . "rezepte_categories");
    Should be about the same, except the part "active". I also tried the old call in the new Plugin, but with the same result.
    101
    Hi there Larina,
    Hi aproape,
    That's good and bad both :-)
    Yes, because the old plugin doesn't use the Dynamics functions.
    Sounds to me like there is some trouble using the [fetch_cat_url] and [fetch_entry_url] functions.. maybe when Dynamics is installed on multiple instances?
    Hmm. How much do you trust your possible future mate? :-)
    I would need to see what the output of those functions is.. and debug a bit. We can probably exchange contact info via PM.
    Not sure if they need to be used differently in a multi-instance situation - for a single installation the sitemap is generated without any issues..
    Can anyone else confirm this.. is anyone else experiencing the same problem?
    Cheers,
    aproape
    [almost taken - need a couple more plugins probably? ]
    Mar 2008
    367
    Oh I trust my possible future mate very much!
    Sure, tell me what you need from my side, if you which via PM.
    larina
    101
    Good morning Brian,
    OK - after a bit of troubleshooting with Larina [ :-) ] - the following issue was found..
    The sitemap addon is using the fetch_cat_url function - which is called with the catid variable.. to extract the friendly URL.
    I have confirmed already that the id is passed correctly and the function does gets the proper value..
    However - when the URL returns [either spider-friendly or not] it's empty - it seems that somewhere on calling fetch_cat_url or inside there - the id is lost.. and.. it's broken.
    Any idea what can do that.. ? Or.. where/how to test it further - to find out?
    On my system - the addon works flawlessly..
    Cheers,
    aproape
    359
    Mar 2008
    367
    Hi Brian,
    would you mind to take a look at aproape's post #9 ?
    Why does this work for others but not for me? Perhaps as I try to use this for the second instance of dynamics? What can I do?
    larina
    Smile
    aproape:
    It works like a charm!
    A big big big Thank you!
    101
    Heya tintin!
    You're welcome ;-)
    Sorry Larina.. I will make sure it's working before the vows!! ;-)
    Cheers,
    aproape
    Mar 2008
    367
    Quote Originally Posted by aproape View Post
    Cheers,
    aproape
    Thank you for your help with this, it works like a charm now!
    larina
    Hi,
    When generating a new site map I get the following error:
    Fatal error: Call to undefined function fetch_cat_url() in /homepages/35/d259872388/htdocs/quk/forum/vbseo_sitemap/addons/vbseo_sm_dynamics.php on line 21
    Mar 2008
    367
    Hi mattysheff,
    in the latest release of dynamics, the dynamics-function fetch_cat_url has been renamed to dyna_fetch_cat_url. So you need to change the file vbseo_sm_dynamics.php like that:
    Find
    $url = fetch_cat_url($cat['catid']);
    and replace it with
    $url = dyna_fetch_cat_url($cat['catid']);
    larina
    Thanks I've tried that but still seem to be getting the same error.
    Mar 2008
    367
    Oh well, I just wanted to upload my whole file for you, but it does not produce seo-friendly-url's anymore No errors like yours, but no seo-url's. They must have been lost with a fix Brian made for dynamics, cause after the first install of the latest dynamics-version the sitemap-plugin was working fine.
    Probably we'll have to wait until aproape made an update for the hack, I saw him posting today in another thread, that this is on his plan.
    larina
    Mar 2008
    367
    I took the time to look deeper into it and found out, that the fix aproape gave to me earlier is working fine with the new dynamics version. Sorry, somehow I was trying the version in this thread after upgrading.
    Anyway, I have attached the file which is working. Be sure you follow the instructions at the top of the file.
    For multi-instances you need to replace adv_dyna in the file everywhere it appears with the table-name you use for your instance (only where adv_dyna is written in small letters).
    larina
  1. Adding vBadvanced Dynamics to VBSEO Sitemap
    By FrontRunner in forum Troubleshooting & Problems
    Last Post: 10-10-2008, 11:20 AM
  2. vBa Integration with SiteMap for vB3.7 Hack on vB.org
    By NashChristian in forum "How Do I..." Questions
    Last Post: 03-11-2008, 02:09 PM
  3. VBA, vBSEO and Me - few Q's
    By Rev O in forum Pre-Sale Questions
    Last Post: 01-25-2008, 09:15 AM
  4. vBadvanced and vbSEO?
    By zurv in forum "How Do I..." Questions
    Last Post: 02-27-2006, 11:35 PM
  5. [REQUEST] Sitemap
    By Impreza04 in forum Module & Modification Discussion & Requests
    Last Post: 08-31-2005, 05:00 PM
