Thread: sql error: Column 'catid' in where clause is ambiguous
    Apr 2004
    18
    Default sql error: Column 'catid' in where clause is ambiguous
    Database error in vBulletin 3.7.3:
    SELECT links.linkid
    FROM adv_links AS links
    LEFT JOIN adv_links_categories AS categories ON (links.catid = categories.catid)
    WHERE links.valid = 1
    AND catid = 2 AND links.userid = 11630
    ORDER BY categories.title ASC;
    MySQL Error : Column 'catid' in where clause is ambiguous
    Error Number : 1052
    Request Date : Wednesday, October 15th 2008 @ 04:58:12 AM
    Error Date : Wednesday, October 15th 2008 @ 04:58:12 AM
    Script : http://www.vvv.com/links/showlink.ph...nkuserid=11630
    Referrer :
    IP Address : 38.98.xxx.xx
    Username : Unregistered
    Classname : vB_Database
    MySQL Version :
    Thank you for pointing this out. I've went ahead and applied the fix to the forum/includes/vba_links_plugin_sf.php file in the download package here, so if you will download the files again and update that one on your server, that should take care of the issue.
    Or if you would rather apply the fix manually, just look in the file for this line:
    $linkquery 'AND catid = ' $catid
    $linkquery 'AND links.catid = ' $catid
    Apr 2004
    18
    $linkquery = 'AND links.catid = ' . $catid;
    Thanks... I think my copy/paste buttons are acting up.
  1. double catid on sort links
    By briansol in forum Troubleshooting & Problems
    Last Post: 09-12-2008, 02:12 AM
  2. Get $cats[catid] into adv_dyna template
    By stitch in forum "How Do I..." Questions
    Last Post: 05-12-2008, 03:56 PM
  3. Unknown column 'links.rating' in 'order clause'
    By Shelby in forum Troubleshooting & Problems
    Last Post: 01-09-2007, 06:01 PM
  4. MySQL Error: 1052 : Column 'dateline' in order clause is ambiguous
    By Bailx in forum Troubleshooting & Problems
    Last Post: 08-23-2006, 04:55 PM
  5. Column 'iconid' in from clause is ambiguous
    By stitch in forum Troubleshooting & Problems
    Last Post: 11-16-2005, 05:44 PM
