Thread: Global vBadvanced Settings - what is this for exactly ?
    Oct 2008
    Default Global vBadvanced Settings - what is this for exactly ?
    I was looking for a way to add meta keywords to my new vBadvanced homepage, for search engine optimization and wondered if Global settings is it ? I suspect not, in which case, what is it for really and how do I optimize search possiblties ?
    www.practicalmachinist.com
    (on edit) Ok, just looked at source code on my new homepage and see my meta keywords from the regular forum pages are showing so I guess that answers that.... so what the heck is Global settings (header, navbar and footer) for ??
    Hey Milacron, been a long time lurker at your site, signed up when you switched to VB.
    The Global setting are used for when you need something prefixed with your forum url.
    Example, my login, search, member list and FAQ were added to my header template as well an the navbar. So I added
    search.php
    login.php
    member.php
    faq.php
    To my header replacements, that way when some one clicks on any of those links in my header they are prefixed with .../forums/
    If I didn't do that - search.php would have been parsed to
    http://www.jeep-cj.com/search.php
    instead of
    http://www.jeep-cj.com/forums/search.php
    Oct 2008
    Thanks Phil...you have a nice looking site. OK I "sort of" get it, but I still don't understand what "good" that actually does ??
    Thanks for the compliment...
    Quote Originally Posted by Milacron View Post
    It's not really the 'good' it does but the reason it does it.
    Example. On your site the forums are in the directory /vb but your CMPS is in the root.
    If you are on the CMPS page the links in the navbar would be incorrect. The link for the FAQ would parse to
    http://www.practicalmachinist.com/faq.php (dead link)
    not
    http://www.practicalmachinist.com/vb/faq.php (good link)
    because in the navbar they are hard coded as relative - not absolute. The replacement option simply adds the forum url http://www.practicalmachinist.com/vb/ in front of the FAQ link (faq.php) instead of the CMPS url http://www.practicalmachinist.com/
  1. Global VBAdvanced Settings
    By 1QuicksSI in forum Troubleshooting & Problems
    Last Post: 02-26-2008, 09:09 PM
  2. Global Advanced Settings page content missing
    By Suzie in forum Troubleshooting & Problems
    Last Post: 01-06-2008, 01:02 AM
  3. Global PhotoPost vBGallery Settings Question
    By SARMX in forum "How Do I..." Questions
    Last Post: 02-11-2006, 01:01 PM
  4. Where do I find 'Global vBadvanced Settings' group
    By direland in forum Troubleshooting / "How do I..." Questions
    Last Post: 04-01-2005, 12:24 PM
