Results 1 to 9 of 9
Thread: Login issues - CMPS Homegae
    Nov 2008
    Default Login issues - CMPS Homegae
    I installed the vbadvanced CMPS system on my forum yesterday.
    The installation went well without any problem. But there's one problem which I can't get it to work.
    I have the cmps on my homepage. ie: http://www.webicy.com/ & the forums is located at http://forums.webicy.com/
    When I try to login from the cmps it brings me back to the same page and again has the username password box. It doesn't show me logged in although I've logged in. When I go to the forum its shows me logged in.
    I've gone through the instructions and checked all the settings, .htaccess file but to no luck.. All works well except for the login issue!!
    I would appreciate if someone can help me fix this issue.
    SticKer
    Jul 2006
    teh Ether
    322
    If my post was helpful to you, or made you or ,
    please take the time to register at my forum and ask
    a question you've always wanted to know about floors.
    Nov 2008
    I've tried the steps given in the faq but didn't help!!
    Try again. If you follow all of the steps there, including clearing your cookies after each change, then one of the configurations there will work.
    Nov 2008
    Okay I'll go through the process once again!
    Nov 2008
    Hi Brian,
    I went through the process once again but it didn't work out.
    Another thing I found out is its not a cookie issue coz when I have the cmps_index file in the forum directory it works well and shows that I'm logged in. But if I have the cmps anywhere other than the forum directory that's when the login problem starts.
    I've set the forum path in the cmps file and the page loads fine. Just wanted to ask you, I have vbseo sitemap plugin installed I hope that's not causing a problem?
    SticKer
    What do you have set for your 'Cookie Domain' and 'Path to Save Cookies' options?
    Nov 2008
    Brian, I got the problem fixed. I changed the cookie setting to .webicy.com and that fixed the problem.
    Thanks for all your help!
    SticKer
    Sep 2008
    16
    same issue, different site, i tried all of the things in the troubleshooting link and still no luck, i even did the above and it did nothing
    nvm, changed Cookie domain to .SITE.com and now it works, for some reason when i did that before it didnt
  1. Login Issues
    By The 360 Place in forum Troubleshooting & Problems
    Last Post: 07-29-2008, 06:57 PM
  2. v3.0 RC2 - Login from CMPS issues - Forum on a subdomain
    By MrEyes in forum Troubleshooting & Problems
    Last Post: 01-21-2008, 11:38 AM
  3. Login Issues with IE7
    By satfix in forum Troubleshooting & Problems
    Last Post: 10-02-2007, 03:53 PM
  4. Login Issues
    By ferocity302 in forum Troubleshooting & Problems
    Last Post: 04-05-2007, 02:02 PM
  5. More Login Issues
    By msgotit in forum Troubleshooting & Problems
    Last Post: 10-27-2005, 01:43 PM
