Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 67
Thread: Latest or Hot Links Module (Updated for version 3 of Links Directory)
  1. #41
    Sep 2004
    450
  2. #42
    Quote Originally Posted by ttnb View Post
    Here is mine
    Nice! I would like to make a multi-row center block.
    Can you share your instructions for making this into a center block.
    THANKS!
    Kamikage
  3. #43
    Sep 2004
    450
    I follow this
    http://www.vbadvanced.com/forum/show...9&postcount=17
    and change "5"to "3". And uncomented to lines I do not use in the template.
  4. #44
    Hi larina and all
    Thanx for the mod, and the modi mod for featured.
    Can I show some of the featured with random links at the same time?
    IE if I have the mod to show 5 links, and I have 2 featured links, I want the 2 featured links to show all the time, and the other 3 to be randomly picked, can this be done?
    Thanx in advance
    Hani
  5. #45
    Oct 2009
    11
    Great module. Tx for it. I installed it at www.pedicabforum.com and have to questions:
    1. How to configure that latestes entries or random are showed? On my site are random showed, but I would like to show the latest entries.
    2. In the sidebar is "Latest Links" - but clicking it goes always to my forum instead to the directory....how to change it?
    Thank you and again: Good work
  6. #46
    1,694
    Quote Originally Posted by Trixi.com View Post
    1)You edit the setting in the module file.
    <?php
    // The order you would like to pull the links in.
    //Enter 1 for newest, 2 for most viewed, 3 for most comments, 4 for highest rated, 5 for random
    $order = 5;
    // Enter the number of links you would like to display here
    $limit = 5;
    // Maximum characters of the links name before the rest will be replaced with '...'
    // Set this to 0 to disable it.
    $maxnamechars = 0;
    // No further editing necessary
    switch($order)
    2)
    . According to where you have installed Links Directory, you need to make one last step:
    Assuming you are using links directory like that: http://www.domain.com/links/ change the links in the template adv_portal_linkbits like that:
    <a href="/links/$linkurl/showlink.php?$session[sessionurl]do=showdetails&amp;l=$link[linkid]">$link[name]</a>
    <a href="/links/$linkurl/browselinks.php?$session[sessionurl]c=$link[catid]">$link[catname]</a>
    Last edited by CareyCrew; 10-17-2009 at 08:54 AM. Reason: added code from .php file
    Seen vB5 beta? No more vbulletin for me, done , gone,finished .
  7. #47
    Oct 2009
    11
    Thank you very much. Now I changed from random to newest. Thanx a lot.
    Regarding the second question / answer: This is what I have in my template:
    <td class="$getbgrow">
    <div><a href="/links/$linkurl/showlink.php?$session[sessionurl]do=showdetails&amp;l=$link[linkid]">$link[name]</a></div>
    <div class="smallfont">
    <br />
    <a href="/links/$linkurl/showlink.php?$session[sessionurl]do=showdetails&amp;l=$link[linkid]" target="_blank">
    <img src="http://open.thumbshots.org/image.pxf?url=$link[linkurl]" border="0" alt="$link[name]" /></a><br /
    So the links itself and the thumbnail they are forwarded well (to the individual entry)...I mean the title in the block "Latest links"....Where to change it on the way that it points to the directory?
  8. #48
    Feb 2009
    For some reason the thumbs and links displayed are not bring me to the said site, i know its gotta be simple but cant figure out where to edit to get it to work. Heres the site .
    http://www.myenlistment.com
  9. #49
    Nov 2007
    Nashville, Tennessee
    249
    Will this still work with vB4, and can it be used to create a module to display on the vB CMS home page?
    Thanks.
  10. #50
    Is there a way to pull links from every category except 1? Kind of like there is an option to ignore categories on the newest/random links on the main link page already. Also please confirm that links a user doesn't have permission to see won't be displayed.
  11. #51
    Jan 2008
    15
    How can these working with friendly urls?
  12. #52
    Sep 2005
    Working VB4 - CMPS v4.0.0 - Links Directory 4
    but What does the following error
    Warning: fetch_template() calls should be replaced by the vB_Template class. Template name: adv_portal_linkbits in [path]\includes\functions.php on line 4097
    Warning: fetch_template() calls should be replaced by the vB_Template class. Template name: adv_portal_latestlinks in [path]\includes\functions.php on line 4097
  13. #53
    Nov 2004
    23
    Well, it works!
    Thanks for that.
  14. #54
    Dec 2008
    6
    can you show me demo ? i still dont understand what do it use for?
  15. #55
    Mar 2008
    367
    Demo of mine: www.feelinggood24.de
    At the left the module called "Weblinks".
    The hack takes links from vBa links directory to show in a module.
    larina
  16. #56
    Maybe I'm missing something or perhaps I'm all coded and modded out but two questions... 1 how do you add these two templates (bearing in mind I'm not a coder and don't have any fancy php editors or anything like that, just wordpad
    Quote Originally Posted by larina View Post
    1. To install, first add these two templates:
    $linkbits
    adv_portal_linkbits
    <div><a href="$linkurl/showlink.php?$session[sessionurl]do=showdetails&amp;l=$link[linkid]">$link[name]</a></div>
    $vbphrase[by]
    <if condition="$link['userid']"><a href="$vboptions[bburl]/member.php?$session[sessionurl]u=$link[userid]">$link[username]</a>
    <else />
    $vbphrase[guest]
    </if><br />
    $link[date] <span class="time">$link[time]</span><br />
    <a href="$linkurl/browselinks.php?$session[sessionurl]c=$link[catid]">$link[catname]</a><br />
    $link[posts] $vbphrase[replies], $link[views] $vbphrase[views]
    and 2, where do you edit these anyway?
    4. According to where you have installed Links Directory, you need to make one last step:
  17. #57
    Mar 2008
    367
    You need to add the templates inside vbulletin adminc:
    Styles & Templates - Manage Styles - here choose the style you use and select in the drop-down "add new template".
    If you later need to edit the templates:
    Styles & Templates - Search templates
    larina
  18. #58
    I've done this and it shows up ok etc etc but when you click on the link to the latest link it directs you to the forum home page
    my links directory url is
    http://midlandsheritage.co.uk/links/index.php
    home url is
    http://www.midlandsheritage.co.uk/
    for the above I've tried using this (for both edits)
    and also
    <a href="/http://midlandsheritage.co.uk/links//$linkurl/showlink.php?$session[sessionurl]do=showdetails&amp;l=$link[linkid]">$link[name]</a>
    and its still directs you to the forum home page...
    the whole code in the template is this
    $vbphrase[by]
    <else />
    $vbphrase[guest]
    </if><br />
    <a href="/links/$linkurl/browselinks.php?$session[sessionurl]c=$link[catid]">$link[catname]</a><br />
    any thoughts/ suggestions as I'm beginning to wish I'd never had this software and rapidly running out of patience
    edit
    I've tried to get it so it doesn't show the thumbnails as I don't want them showing
  19. #59
    Mar 2008
    367
    I'd try this link-format:
    <a href="http://www.midlandsheritage.co.uk/links/showlink.php?$session[sessionurl]do=showdetails&amp;l=$link[linkid]">$link[name]</a>
    <a href="http://www.midlandsheritage.co.uk/links/browselinks.php?$session[sessionurl]c=$link[catid]">$link[catname]</a>
  20. #60
    That would make the complete code
    <div><a href="http://www.midlandsheritage.co.uk/links/$linkurl/showlink.php?$session[sessionurl]do=showdetails&amp;l=$link[linkid]">$link[name]</a></div>
    $vbphrase[by]
    <else />
    $vbphrase[guest]
    </if><br />
    <a href="http://www.midlandsheritage.co.uk/links/$linkurl/browselinks.php?$session[sessionurl]c=$link[catid]">$link[catname]</a><br />
    and its stills just directs you to the hoempage thanks anyway
  1. Latest or Hot Links Module (CMPS 2.2.1 + Links D.2.0rc1)
    By nostalgia in forum Add-On Modules (version 3.x & 2.x)
    Last Post: 03-06-2009, 10:25 PM
  2. Replies: 1
    Last Post: 06-02-2008, 12:57 PM
  3. Replies: 2
    Last Post: 05-14-2007, 01:31 PM
  4. vBa Links Directory Updated For vB 3.6
    By Brian in forum Announcements
    Last Post: 10-02-2006, 11:34 AM
