Thread: Welcome Block problems w/ Disabling Avatar
    Default Welcome Block problems w/ Disabling Avatar
    I'm having some minor issues after upgrading to CMPS 3.01. I have the Welcome Block displayed on my homepage. It displayes the "no avatar selected" image even for users that have avatars.
    It is also set to not display the avatar and to be in brief mode. Neither of those settings are working. Any ideas? The diagnostics shows all okay except for the missing admincp/vbacmps_install.php file.
    Sep 2004
    HSV
    276
    I'm having similar problems. I've set the welcome block to not display the avatar and it still does. My test site doesn't have any avatars, so it keeps displaying the 'no avatar' image.
    I've checked diagnostics, and it's kinda weird. Under version it says "version information in currently unavailable". It also says that vb cmps is disabled in installed products, but it's not. Everything else is showing ok.
    Any assistance appreciated.
    Thank you for pointing this out. Looks like there was a small bug in the modules/welcomeblock.php file that was allowing the "no avatar" image to still be displayed. I've just applied the fix to that file in the download package here, so if you will download the files again and update that one on your server, then that should take care of the issue.
    Sep 2004
    HSV
    276
    Thank you Brian!
    If the fix is minor enough, do you mind posting it here so I can just edit my file?
    It's more than just a line or two that was changed, but you can look in the file for this code:
        // Avatar
    if ($mod_options['portal_welcome_avatar']
            AND
    $vbulletin->userinfo['showavatars']
            AND (
    $vbulletin->userinfo['avatarid']
                OR (
    $vbulletin->userinfo['permissions']['genericpermissions'] & $vbulletin->bf_ugp_genericpermissions['canuseavatar'])
                OR
    $vbulletin->userinfo['adminavatar']
            require_once(
    DIR '/includes/functions_user.php');
    $avatarurl fetch_avatar_url($vbulletin->userinfo['userid']);
            if (
    $avatarurl[0])
    $avatarurl $vbulletin->options['bburl'] . '/' $avatarurl[0];
            else if (
    $mod_options['portal_noavatarurl'])
                eval(
    '$mod_options[\'portal_noavatarurl\'] = "' addslashes($mod_options['portal_noavatarurl']) . '";');
    $avatarurl $mod_options['portal_noavatarurl'];
        else if (
    $vbulletin->options['avatarenabled'])
            eval(
        // Avatar
    $avatarurl '';
        if (
    $mod_options['portal_welcome_avatar'])
            if (
                AND (
                    OR (
                    OR
                require_once(
                if (
    $avatarurl[0])
                else if (
                    eval(
            else if (
                eval(
    Sep 2004
    HSV
    276
    Thank you very much Brian! *rushes to change code*
  1. Welcome Block Avatar size ?
    By Onehalfmoa in forum "How Do I..." Questions
    Last Post: 12-06-2008, 12:34 PM
  2. No avatar in usercp block
    By TsirhCitna in forum Troubleshooting & Problems
    Last Post: 06-13-2008, 05:21 PM
  3. User CP Block - Avatar
    By Morrow in forum Troubleshooting & Problems
    Last Post: 04-10-2006, 06:59 PM
  4. welcome block - avatar/profile pic
    By majorj0nny1 in forum Troubleshooting / "How do I..." Questions
    Last Post: 05-28-2005, 08:23 PM
  5. Avatar in news block.
    By bigcurt in forum Troubleshooting / "How do I..." Questions
    Last Post: 02-26-2005, 01:00 AM
