Thread: Database Error: Unknown column 'links.rating'
    Default Database Error: Unknown column 'links.rating'
    Hi,
    I upgraded to the latest links directory, now I am getting this error via Email:
    Database error in vBulletin 3.8.1:
    				SELECT  links.linkid
    				FROM rife_adv_links AS links
    				WHERE links.valid = 1
    					 AND userid = 1
    				ORDER BY links.rating DESC;
    MySQL Error   : Unknown column 'links.rating' in 'order clause'
    Error Number  : 1054
    Request Date  : Friday, February 13th 2009 @ 01:42:03 AM
    Error Date    : Friday, February 13th 2009 @ 01:42:03 AM
    Script        : http://www.rifeforum.com/links/showlink.php?l=22&goto=next&catid=member&orderby=directory&linkuserid=1
    Referrer      :
    IP Address    : 77.88.25.27
    Username      : Unregistered
    Classname     : vB_Database_MySQLi
    MySQL Version :
    How do I fix this?
    Thank you for pointing this out. I'm guessing somebody followed an old link to produce that error. I've updated the forum/includes/vba_links_plugin_sf.php file here to add some code that will prevent that error, so if you'll download the files from here again and update that one on your server, that should take care of the issue.
    Apr 2005
    6
    Bug in search.php:
    Invalid SQL:
    SELECT links.linkid
                FROM adv_links
    AS links
                WHERE
    MATCH(links.nameAGAINST ('+Autodesk*' IN BOOLEAN MODE) OR MATCH(links.descriptionAGAINST ('+Autodesk*' IN BOOLEAN MODE) OR MATCH(links.keywordsAGAINST ('+Autodesk*' IN BOOLEAN MODE)) AND  links.valid IN(012)
    ORDER BY links.rating ASC LIMIT 500;
    MySQL-Fehler  Unbekanntes Tabellenfeld 'links.rating' in order clause
    Fehler
    -Nr.    : 1054
    Fehler
    -Zeit   Friday20.03.2009 18:29:50
    Datum
    Skript
    http://www.3dmaxforum.net/links/search.php?do=searchresults&string=Autodesk&catid=0&quicksearch=1&tag=1
    Referrer      http://www.3dmaxforum.net/links/showlink.php?l=1
    IP-Adresse    77.179.12.73
    Benutzername
    Andreas
    Klassenname
    vB_Database
    MySQL
    -Version 5.0.32-Debian_7etch8-log
  1. MySQL Error: Unknown column 'dodeleted'
    By natas in forum Bugs From 3.0.0
    Last Post: 09-12-2008, 12:36 PM
  2. Unknown column error
    By Pingu in forum Troubleshooting & Problems
    Last Post: 09-29-2007, 08:34 AM
  3. Unknown column 'links.rating' in 'order clause'
    By Shelby in forum Troubleshooting & Problems
    Last Post: 01-09-2007, 07:01 PM
  4. DB Error: Unknown column 'phrasegroup_adv_links'
    By Freesteyelz in forum Troubleshooting & Problems
    Last Post: 09-09-2006, 09:18 AM
  5. database error when rating
    By thorzzzten in forum Troubleshooting & Problems
    Last Post: 09-22-2004, 02:14 PM
