Thread: Own thumbnails instead of thumbshots
    Dec 2005
    Dublin
    31
    Lightbulb Own thumbnails instead of thumbshots
    I've managed to replace the thumbshots images with my own, which is much better suited for my purpose. I figured I'd share here.
    This is the simplest way to do this however it will require some work at your end for maintenance - best suited to the situation whereby the owner of the site is uploading all links.
    First of all create thumbnails as you would like them to be and upload to a specific directory, I use "domain/images/library/"
    Each thumbnail should be named for your linkid, so 1.jpg 2.jpg etc and all need to have the same extension.
    Next, do a search in your templates for
    src="http://open.thumbshots.org/image.aspx?url=$link[linkurl]" width="120" height="90"
    and replace with
    src="http://your.domain.and/path/$link[linkid].jpg" width="120" height="90"
    Of course if you want to change the height/width variables, this is where you'd do that.
    I found two templates where I had to do this.
    Works a treat.
    can you shoot a link to your site? i will like to see the outcome, doing this I will have to add the thumnail for each link or just the ones I want to change for example the ones that thumshots.com fail to recognize?
    359
    how at least grab the thumbnail ot how to generate the thumbnail
    where is the file for this
  1. Thumbshots.com - image coming soon
    By ibaker in forum Troubleshooting & Problems
    Last Post: 04-15-2010, 06:33 AM
  2. Thumbshots issue
    By Lionel in forum Bugs From 3.0 Beta 2
    Last Post: 10-11-2009, 12:53 PM
  3. Remove Thumbshots Link
    By EasyRider in forum "How Do I..." Questions
    Last Post: 09-08-2008, 11:23 AM
  4. Couple of questions - thumbshots, affilate url's
    By kyle in forum "How Do I..." Questions
    Last Post: 08-07-2008, 11:57 AM
  5. Thumbshots.org - Integration
    By interfx in forum Pre-Sale Questions
    Last Post: 11-25-2004, 09:12 AM
