Results 1 to 9 of 9
Thread: Invalid Forum Path! Please Help
    Jul 2009
    Default Invalid Forum Path! Please Help
    Okay so I am installing vBadvanced CMPS in my vBulletin forum folder. I followed all the instructions for installing it there but when I go to my forums I get:
    "Invalid forum path specified! Please edit this file and be sure to include the correct path for your $forumpath variable."
    Please help me. http://www.unlimitedglitching.com/forum
    By the way I left the forum path empty since it is in my vBulletin folder. Then I thought maybe I do need to change it to where it is located but it still doesn't work.
    May 2008
    Sarasota, Florida
    302
    CHIMPIE | SKYWARN
    "I have found Chimpie to be very professional, knowledgeable, prompt, and reasonably priced."
    "I would not hesitate to utilize his services again in the future, and I highly recommend him."
    Jul 2009
    Okay I did that and got my forum path and used it but it still gives the same error.
    Try this:
    $forumpath = './forums';
    Jul 2009
    I tried that too and it also didn't work. I just can't seem to figure out what is wrong. I haven't removed the install file yet, you that be it?
    It wouldn't have anything to do with the install file being removed. If the file is saying that your $forumpath is incorrect, then an incorrect path is the only cause.
    The only thing I can suggest is to try the forumpath.php file again, make sure you're uploading it to the same folder that contains your vBulletin files, and then copy that path exactly.
    Jul 2009
    Okay well thanks for your help, I'll let you know if I resolve it.
    May 2009
    Try this:
    Does the diagnostics part of vbadanced work no matter what I put for forum path it gives me an invalid link, my cmps_index.php is in root dir. rename to index.php. I have run the forumpath file 3 times copied and pasted the response still same error, at 1st I left file alone since I put it in root dir then when I could not get rid of this error I tried insert link into index.php file between the ' ' and still same error.
    Jul 2014
    update, thanks
  1. Invalid forum path specified!
    By hotrodkush in forum Troubleshooting & Problems
    Last Post: 06-21-2010, 03:38 PM
  2. Invalid Forum Path
    By vbpackerfan in forum Troubleshooting & Problems
    Last Post: 03-13-2009, 07:37 PM
  3. Invalid forum path specified!
    By Tranter in forum Troubleshooting & Problems
    Last Post: 04-07-2008, 12:30 AM
  4. Invalid forum path specified
    By jplg in forum "How Do I..." Questions
    Last Post: 01-29-2007, 12:15 PM
  5. Invalid forum path
    By Annie^.^ in forum Troubleshooting & Problems
    Last Post: 03-03-2006, 01:59 AM
