Results 1 to 20 of 20
Thread: cron job for deleting entries after 30 days?
    Oct 2005
    186
    Default cron job for deleting entries after 30 days?
    Brian, could you post what it should look like?
    $kill = array();
    $getentries $db->query_read("
        SELECT entryid
        FROM "
    TABLE_PREFIX "adv_dyna_entries
        WHERE dateline <= "
    . (TIMENOW 2592000)
    while (
    $entry $db->fetch_array($getentries))
    $kill[] = $entry['entryid'];
    require_once(
    './includes/vba_dyna_functions_moderate.php');
    delete_entries($kill);
    Oct 2005
    186
    I'll try that out. Thanks!
    Oct 2005
    186
    Hey Brian, I'm getting an error on this line:
    $getentries = $db->query_read("
    The error is:
    Fatal error: Call to a member function query_read() on a non-object
    I've placed that code into a file, placed it in the cron folder and created a cron job.
    Try replacing the two places you see "$db->" in the code with "$vbulletin->db->" and see if you get better results.
    Oct 2005
    186
    Was thinking that myself - when I tried that, I got the following error:
    Fatal error: Call to a member function query_write() on a non-object in /var/www/mysite.com/web/forums/includes/vba_dyna_functions_moderate.php on line 156
    Figured I was on the wrong path.
    You could try adding this code to the top of your PHP file for the cron job.
    $db =& $vbulletin->db
    If that doesn't help then you may need to edit your includes/vba_dyna_functions_moderate.php file and add that line just below this code:
    function delete_entries($entryarray)
        global
    $db$vba_options
    Oct 2005
    186
    So I've tried adding that line of code to the top of the cron job (while leaving the previous code modifications in, and then reverting them back to the original suggestion), and also adding the modification code to the vba_dyna_functions_moderate.php file... still getting an error:
    Call to a member function query_write() on a non-object in /var/www/mysite.com/web/forums/includes/vba_dyna_functions_moderate.php on line 158
    Ahhh, you probably need to globalize the $vbulletin variable within the function as well.
        global $db, $vba_options, $vbulletin;
        $db =& $vbulletin->db;
    Oct 2005
    186
    Making progres... now getting a db error:
    DELETE FROM ADV_DYNA_TABLE_PREFIXentries WHERE entryid IN
    I figure if maybe I add an underscore in the cron file query, I should be good?
    FROM " . TABLE_PREFIX . "_adv_dyna_entries
    It would probably be better just to add this code near the top of the PHP file you're using for the cron job.
    define('ADV_DYNA_TABLE_PREFIX''adv_dyna');
    Oct 2005
    186
    Got a new error:
    Fatal error: Call to undefined function dyna_fetch_upload_path() in /var/www/mysite.com/web/forums/includes/vba_dyna_functions_moderate.php on line 175
    Well at least we're getting closer.
    Try adding this line to the top of your PHP file, just after the opening <?php tag.
    require_once('./includes/vba_dyna_functions.php');
    Oct 2005
    186
    That did it. It is now finally working. Thanks Brian.
    Oct 2005
    186
    Hey Brian, is there an easy way to add on to this cron script to delete all attachments associated with the entries that are being deleted?
    Here's the code that is being used to delete the entries:
    define('ADV_DYNA_TABLE_PREFIX', 'adv_dyna_');
    $kill = array();
        SELECT entryid
        FROM " . TABLE_PREFIX . "adv_dyna_entries
        WHERE dateline <= " . (TIMENOW - 2592000)
    while ($entry = $db->fetch_array($getentries))
    require_once('./includes/vba_dyna_functions_moderate.php');
    Attachments should already be deleted when the delete_entries() function is run.
    Oct 2005
    186
    Ahhh, that might be the case. I haven't verified whether it's the cron job or when people delete their own entries. But I know that I have attachments that are still stored that are not tied to any entries - as the entries were deleted, but not the attachments. I can't remember if the entries were deleted by the cron job or by me. It causes issues for usergroups that have a limit on their quota, as they have no ads posted but their attachments are still taking up space. Do attachments get deleted when entries are deleted manually by the user?
    If your members are just soft deleting entries then that could be the issue since attachments are not removed when an entry is soft-deleted.
    Oct 2005
    186
    That must be it. Are soft deleted entries physically removed with the cron job? Maybe that's the issue. The entries get soft deleted and the attachments are not deleted. Then, when the cron runs, it doesn't delete the attachments.
    Even a soft-deleted entry should be removed by that code in your cron job, and it should pick up the attachments as well...
  1. Deleting or renaming entries / categories
    By larina in forum Troubleshooting & Problems
    Last Post: 06-28-2008, 03:30 PM
  2. Cron SQL Error
    By dholt in forum Bugs From 2.0 Beta 2
    Last Post: 10-02-2006, 12:08 PM
