Thread: Add an introduction
    Sep 2004
    15
    Default Add an introduction
    Id like to add into about my site etc how would i do this (add module then what?)
    Default Re: Add an introduction
    Start with this http://www.vbadvanced.com/forum/showthread.php?t=1011
    Inside the section where it says
    "Your custom code comes here."
    is where you will add your text.
    If you know any html, you can play with it a bit to change the look and feel and of course, what you want to say
    Sep 2004
    15
    Thank you Added into but how do i add images
    The [img] tag does not work
    If I am not mistaken the bbcode [img] tag will not work, you have to use the html image tag. something like this
    <img src="http://www.Link to your image file.gif">
    HTH
