Thread: Deprecated Warning
    Feb 2005
    Default Deprecated Warning
    every time i access the first time the Links - i get this PHP Deprecated Information:
    Deprecated: Assigning the return value of new by reference is deprecated in \wwwdoc\links\links_global.php on line 44
    Please, could you fix this - i haven´t checked the source code - but it is normally a small "&" who makes the warning.
    I´ve been using PHP 5.3. but the deprecated Information also affects normally the PHP 5.2 Builds.
    Best regards,
    I haven't seen any other reports like this, so it sounds more like this may just be a new issue with PHP 5.3. It doesn't look like the reference there is really necessary though, so you should be able to solve the issue by looking in your links_global.php file for this code:
    $vba_links =& new vba_links();
    $vba_links = new vba_links();
    (just removing the & as you stated)
    Feb 2005
    It isn´t a PHP 5.3 Feature - this is since PHP 5.2.
    Correct - by removing the & the "Notice" disappears.
    You normally don´t see or hear this, because normally the ErrorReporting of PHP is configured without "NOTICE".
    If you turn on NOTICE in Error Reporting - you will see it also on PHP 5.2
    Thanks a lot.
  1. Deprecated error with PHP 5.3.0
    By Coen Jeukens in forum Troubleshooting & Problems
    Last Post: 03-02-2010, 08:05 PM
  2. Warning Error
    By offline in forum Troubleshooting & Problems
    Last Post: 08-29-2007, 11:26 AM
  3. Warning?!
    By 7OXIC in forum Troubleshooting & Problems
    Last Post: 05-05-2007, 10:31 AM
  4. New Install of 2.0.1 warning
    By waller99 in forum Troubleshooting & Problems
    Last Post: 03-01-2007, 06:38 PM
  5. Warning: chdir():
    By Xplorer4x4 in forum Troubleshooting & Problems
    Last Post: 09-29-2005, 10:50 AM
