Results 1 to 18 of 18
Thread: AJAX Tabs Content Script - Version 3.0 (YUI) (vb4 mod fix!)
    Sep 2009
    9
    Default AJAX Tabs Content Script - Version 3.0 (YUI) (vb4 mod fix!)
    I don't take credit for making this entire module bobster65 is the original author. However I did fix recent threads and blogs module to make it compatible with vb4.0 and compatible with IE6.0/7.0/8.0/9.0 since it wasn't publicly available yet. The blog module is also compatible with the CMS release of blogs.
    Please follow the instructions on how to install the YUI tabs below from this link
    http://www.vbadvanced.com/forum/showthread.php?t=31617
    For the tabs use the ones attached below as samples. Remember you must edit the forumid's in the tabsample for them to show up properly.
    Example: http://www.freefrag.com/
    Thanks for looking.
    Mar 2010
    Hi,
    Thank you for your work, but I have a problem, the umlauts are shown in the article incorrect. In the rest of the forum everything works properly. see picture.
    Sep 2009
    9
    the articles? you mean forum posts or blogs? i didn't post a script for article :P also what picture?
    Mar 2010
    oh, I've accidentally deleted images. sry my english is bad.
    Yes, I mean forum post.
    has something to do with the charset? how do I change it?
    I have utf-8
    Sep 2009
    6
    Quote Originally Posted by Inflikted View Post
    Thanks for looking.
    You may want to review the code for this. I don't know if it's a new vbulletin update or what - but this script seriously causes some problems in IE8 with smilies and formatting. Seems to work in Firefox still. But in IE8 you'll see "error on page" in the bottom left corner, and clicking on smilies does nothing - in fact, when you respond to threads, none of the toolbars work. It's almost like this script just disables the buttons.
    I've narrowed it down specifically to this:
    <!-- YUI CSS for TabView -->
    <link rel="stylesheet" type="text/css" href="clientscript/yui/tabview/assets/tabview.css" />
    <link rel="stylesheet" type="text/css" href="clientscript/yui/tabview/assets/tabview-skin.css" />
    <!-- JavaScript Dependencies for Tabview: -->
    <script type="text/javascript" src="clientscript/yui/utilities/utilities.js"></script>
    <script type="text/javascript" src="clientscript/yui/element/element-beta-min.js"></script>
    <!-- Source file for TabView -->
    <script type="text/javascript" src="clientscript/yui/tabview/tabview-min.js"></script>
    <!-- Source file for Dispatcher -->
    <script type="text/javascript" src="clientscript/yui/tabview/dispatcher-min.js"></script>
    Sep 2009
    9
    ah i forgot to mention one thing.. thats wrong with bobster65 instruction. instead of placing the javascript loading there.. you want to actually place it in adv_portal template right above your {vb:raw header}
    That will do two things for you, it should stop the conflict you are having with possibly another javascript based plugin in your forum, and number two it will conserve bandwidth dramatically by only loading the tab javascript files on your frontpage only, the method bobster gave would load it on every single forum page that has a header.
    Sep 2009
    6
    Awesome - thanks! Looks like that did the trick.
    By the way - one minor suggestion in the blog tab file. As it is, it doesn't have a class assigned to the TR tag in the data output area. I changed it to the following so I have the table lines as shown in the tabsample1.php file.
    In tab_blog2.php, I changed line 94 from:
    echo '<tr>
    To:
    echo '<tr class="vba_module">
    Now I just need a random/latest photos block with thumbnails and image titles, and I'll be all set! I seriously suck at PHP. The old one for vb3 tabs doesn't work on vb4 so I lost that feature in the upgrade.
    Jun 2009
    19
    Where's the demo at your site? Not new newsfeed, isn't it?
    Jonas
    Sep 2009
    9
    sorry with the newest update of vb 4.0.3 and vbadvanced this no longer works with IE. you will need to wait for the original author to update the backend YUI script so its compatible with IE. thats why you don't see it on my site.
    Jun 2009
    19
    Could you tell me how you had intregrate the slideshow into your cmps?
    Jonas
    Does it work fine on Vb4.0.2 and Vba 4 Gold ?
    If you want Vbadvanced Customized main page,PM me
    Hi,
    Your slider is installed on vbadvanced?
    Please let me know, I urgently need one like yours.
    Apr 2009
    11
    not work ((((
    May 2010
    11
    Work perfect, but do you make the file "tab_news.php" ready for vb4?
    I really need this, hope you can change this ^^
    thanks.^^
    Problem:
    How i can add Umlauts äöü >.<
    May 2010
    11
    Quote Originally Posted by Sayuuki View Post
    thanks.^^
    Problem:
    Nobody help?
    May 2010
    11
    Nobody help?
    I still search for a modification to fix the Umlauts and Tab_News for vb4...
    can nobody help?
    May 2010
    11
    push*
    Nobody can help Oo?
    Apr 2009
    11
    Help!!!
    ����� 21:56
    by record rulit
  1. AJAX Tabs Content Script - Version 3.0 (YUI)
    By bobster65 in forum Add-On Modules (version 3.x & 2.x)
    Last Post: 06-01-2018, 05:50 AM
  2. AJAX Tabs Content Script v2.0 enhanced
    Last Post: 07-01-2010, 12:05 PM
  3. vba.com forum suggestion - AJAX Tabs Content Script
    By paintballer.ie in forum Site Feedback & Updates
    Last Post: 12-28-2009, 01:20 PM
  4. Slideshow and AJAX Tabs
    By glorify in forum Show off your vBadvanced!
    Last Post: 04-27-2009, 07:07 PM
  5. AJAX Tabs not rendering correct on Opera browser
    By glennybee in forum Module & Modification Discussion & Requests
    Last Post: 03-13-2008, 04:26 PM
