Results 1 to 11 of 11
Thread: vBadvanced CMPS 4.0.0 GOLD Spanish Languaje Pack
    Default vBadvanced CMPS 4.0.0 GOLD Spanish Languaje Pack
    Hello everyone.
    After a couple of days of work, vBulletin Hispano - The Leading vBulletin Community in Spanish Support has been completed the vBadvanced CMPS Spanish Translation.
    Here a few details about vBa and download package:
    http://www.vbadvanced.com/products.p...fo&productid=4
    Traducción vBa CMPS 4.0.0 - vBHispano.zip File Contents
    The *.zip file contains two files named vba_cmps-spanish-languaje-4.0.0-product.xml and vba_cmps-spanish-languaje-4.0.0.xml. Here are technical details:
    *.zip file size: 22,6 KB
    vba_cmps-spanish-languaje-4.0.0-product.xml file size: 6 KB
    vba_cmps-spanish-languaje-4.0.0.xml file size: 114 KB
    Number of sentences: 546
    QA: Andrés Durán
    How to Install:
    1. Download and unzip 'Traducción vBa CMPS 4.0.0 - vBHispano.zip' file.
    2. Go to:
    AdminCP -> Idiomas y Frases -> Descargar / Subir Idiomas
    3. In the 'Importar Archivo XML del Idioma' area browse and select the vba_cmps-spanish-languaje-4.0.0.xml file, then set the following options:
    Sobrescribir Idioma: Español
    Título para el Idioma a Subir: Lo dejan en blanco
    Ignorar Versión de Idioma: Sí
    4. Click on 'Importar' button
    5. After that, go to:
    AdminCP -> Plugins y Productos -> Administrar Productos -> [Agregar/Importar Producto]
    6. In the 'Importar Producto' area browse and select the vba_cmps-spanish-languaje-4.0.0-product.xml file
    7. Click on 'Importar' button
    That's all!!, now you'll have your vBa CMPS fully translated into spanish.
    If you have any further questions and need technical support in spanish, please go to:
    And feel free to ask for help. I'll be more than glad to assist you in our native languaje.
    Enjoy!!.
    Best regards,
    Andrés, vBulletin Hispano Leader
    ** For spanish customers: **
    Traducción Español vBadvanced CMPS v4.0.0 y superiores
    vBadvanced es un sistema "portal" que permite colocar en portada los temas más recientes o relevantes del foro, así como también te brinda la posibilidad de añadir módulos con contenido personalizado (PHP, HTML, códigos BB, etc.). El script es gratuito y se puede bajar en el sitio oficial:
    vBadvanced
    Descripción
    vBadvanced CMPS es un portal avanzado / sistema de administración de contenido que permite la publicación rápida de temas y mensajes relevantes del foro en una página independiente diseñada con módulos escritos en PHP. vBadvanced incluye por defecto 14 módulos personalizables desde un propio Panel de Administración. Crea nuevas páginas fácilmente con contenido personalizado sin necesidad de tener mucha experiencia en lenguajes de programación (requeridos para la escritura y diseño de módulos y/o páginas con diseños avanzados).
    Características
    • Más de 100 características personalizables que hacen sencilla la personalización del script a través del Panel de Administración.
    • Creación y administración sencilla de nuevas páginas y/o módulos a través del Panel de Administración
    • Tipos de página incluidos:
    Módulos
    Código BB
    Plantilla
    Archivo HTML
    Páginas de Archivos PHP
    • Se puede añadir un número ilimitado de módulos sin necesidad de hacks y/o archivos adicionales
    • Control de acceso a cada módulo por grupos de usuarios
    • Administración de permisos para cada página independiente del portal
    • Capacidad de utilizar el editor WYSIWYG a la hora de crear módulos de código BB
    • Completamente traducido (sin frases hardcoded)
    • Código HTML 100% validado por The W3C Markup Validation Service
    • Y mucho más
    Módulos incluidos
    1. Menú de navegación
    2. Bloque de Bienvenida
    3. Módulo de Noticias
    4. Archivo de Novedades
    5. Últimos Temas
    6. Encuestas
    7. Lista de Amigos
    8. Usuarios en Línea
    9. Moderación Rápida
    10. Calendario
    11. Estadísticas
    12. Cumpleaños del Día
    13. Búsqueda
    Contenido del archivo *.zip Traducción vBa CMPS 4.0.0 - vBHispano.zip
    El archivo *.zip contiene 2 archivos *.xml llamados vba_cmps-spanish-languaje-4.0.0-product.xml y vba_cmps-spanish-languaje-4.0.0.xml. A continuación los detalles técnicos:
    Tamaño de Archivo *.zip: 22.6 KB
    Tamaño del archivo vba_cmps-spanish-languaje-4.0.0-product.xml: 6 KB
    Tamaño del archivo vba_cmps-spanish-languaje-4.0.0.xml: 114 KB
    Cantidad de frases: 546
    Duración en la traducción: 2 días
    Control de Calidad: Andrés Durán
    Instrucciones de instalación
    1. Descarga y descomprime en tu ordenador el archivo 'Traducción vBa CMPS 4.0.0 - vBHispano.zip'
    2. Dirígete a:
    3. En la sección 'Importar Archivo XML del Idioma' elijan el archivo vba_cmps-spanish-languaje-4.0.0.xml y especifiquen los siguientes ajustes:
    4. Pulsan el botón 'Importar'
    5. Luego de eso, se dirigen a:
    6. En la sección 'Importar Producto' pulsan el botón Examinar y eligen el archivo vba_cmps-spanish-languaje-4.0.0-product.xml
    7. Pulsan el botón 'Importar'.
    Y listo, tendrán vBadvanced traducido.
    Si tienen alguna pregunta, por favor sírvanse dirigirse a:
    Para recibir asistencia en español. Estaré más que complacidos de asistirlos en nuestro idioma nativo.
    Saludos cordiales.
    Andrés Durán Hewitt / vBulletin Hispano Community Support
    ¿Dudas antes de actualizar a vBulletin 4? - Las mejores prácticas para actualizar
    ¿Quieres traducir add-ons? - Como traducir
    Dec 2008
    Awesome vBHispano... o.O
    Feb 2010
    Hola, me he bajado esta traduccion y cuando la instalo segun el tutorial me aparece arriba esto:
    Warning: array_merge() [function.array-merge]: Argument #2 is not an array in [path]/includes/vba_cmps_include_top.php on line 942
    Warning: array_merge() [function.array-merge]: Argument #1 is not an array in [path]/includes/vba_cmps_include_top.php on line 942
    Saludos
    Hola olympus. Bienvenido a vBadvanced.
    Trata de resolver el problema reconstruyendo el caché de los módulos en:
    AdminCP -> vBa CMPS -> Diagnósticos -> [Reconstruir Caché de Módulo]
    Me dejas saber si eso resolvió tu problema.
    Saludos.
    Feb 2010
    Gracias Chuta, hize lo que me dijiste y se me arreglo
    Saludos
    Jul 2008
    gracias compa ...descargado
    May 2010
    Graciass
    Dec 2009
    muy buena traduccion chuta...... gracias......
    edit: gracias por la solucion del problema...... a mi tambien me funciono.....
    Jan 2006
    Hola gracias por la traducción
    Dec 2010
    Gracias por la traducción y la solución del problema igualmente saludos
    May 2011
    muy bueno espero bajar
  1. vBAdvanced CMPS v4.0 Beta 1 Spanish Language Pack (ES)
    By mcloud in forum Language Packs / Translations
    Last Post: 04-22-2010, 08:52 PM
  2. vBAdvanced CMPS 3.0.1 Spanish Language Pack
    Last Post: 01-09-2010, 07:44 PM
  3. vBAdvanced CMPS v3.2.1 Spanish Language Pack (ES)
    Last Post: 11-05-2009, 11:47 AM
  4. Spanish Language Pack (Lenguaje español)
    By Coletta in forum Language Packs / Translations
    Last Post: 08-25-2008, 07:38 PM
  5. Spanish - Language pack
    By Daiver in forum "How Do I..." Questions
    Last Post: 06-21-2005, 03:22 PM
