Thread: Importing link data
    Toronto, Ontario
    46
    Default Importing link data
    The lack of any importing features has been the main reason I've put off getting the otherwise fantastic vBa Links software. Is there any possibility that we can see some sort of import functionality in the near future? Even a "yeah, probably for 5.0" might cut it.
    Every other links directory script worth its salt offers this sort of thing, and though they're stand-alone, I've had to seriously consider going with one of them and dealing with the sloppy integration as a result. This feature would definitely swing me back to vBa.
    Dmoz importing would be fantastic, though there are ways to generate at least a csv or xml list of categories and links so that even a raw import feature here could take care of that.
    CSV/tab/pipe delineated imports would be all that's necessary to start with. XML would be nice too. (Even LDM offers these import options, as well as export for backup.)
    Any thoughts? I have a hand-gathered list of hundreds of sites with url and other information that I would rather import than re-enter. I understand that vBa Links uses modified forums/threads for its directory (doesn't it?), but there must be a way to accomplish this.
    1,694
    The import question came up a few times before and I remember seeing a reply or two saying it had been done......
    this was one reply http://www.vbadvanced.com/forum/showthread.php?t=30482
    whether that is a viable way round the issue I have no idea.
    Toronto, Ontario
    46
    Quote Originally Posted by CareyCrew View Post
    Thx! Yes, I saw that thread before, but was hoping that since then Brian might have changed his mind about adding import functionality to a newer version. I'll take this into consideration.
    Toronto, Ontario
    46
    Hi Brian -- I just wanted to check in to see if there has been any change in plans to support some sort of importing function(s) for vBa Links? (e.g. from CSV/XML files, or a DMOZ importer.)
    Thx!
    There was an option added in v3.3.0 & v4.1.0 to allow you to mass import a list of URL's by simply entering the list in a textbox. It will collect the meta tags from each site (just as if you were submitting them normally) and automatically fill everything out for you.
    I'll likely add some more advanced import/export options in the future, but I can't say when that might be at this time.
    Toronto, Ontario
    46
    Ah, that's fantastic! Thanks, Brian. I guess I missed those in the new-features announcements.
    Excellent news, very promising.
  1. Integration, importing and a few others
    By John D in forum Pre-Sale Questions
    Last Post: 10-27-2007, 01:00 PM
  2. importing data into cmps from a phpBB sql database ?
    By nonnon in forum "How Do I..." Questions
    Last Post: 09-18-2007, 11:29 PM
  3. Custom Field // Dropdown // Data Reset Upon Edit Link
    By hot_turkey_ed in forum Troubleshooting & Problems
    Last Post: 04-26-2006, 08:36 PM
  4. MODULE importing
    By ZIKI-SET in forum Troubleshooting & Problems
    Last Post: 04-14-2006, 03:13 PM
  5. Importing Links
    By interfx in forum "How Do I..." Questions
    Last Post: 09-11-2005, 02:40 PM
