View Poll Results: How was this Solution?
Voters
40. You may not vote on this poll
  • Awesome!
    28 70.00%
  • Not Bad
    5 12.50%
  • Try football
    7 17.50%
Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 91
Thread: MGC Chatbox Evo on Vba 4
    Cool MGC Chatbox Evo on Vba 4
    Notice : This works on Vbulletin 4 ! and Vba 4
    This shout box has so many features like Vbshout, Inferno ,Vsa Chatbox and so many others, and also most friendly with Vba 4. This shout box can import chats from any shoutboxes on Vbulletin. Here you can download it MGC Chatbox Evo
    It has a Vba Module but not for version 4, i have written this instruction for people who wants to make it works on their Vba
    If you want to put your chat box in main page on Vba You should follow these :
    1) Go to ACP/MGC Chatbox Evo/Display And Position
    Find these options
    Position of the chatbox on the forum home (forumhome)
    Position of the chatbox in the forums (forumdisplay)
    Position of the chatbox in the threads
    Make them: Do Not Display
    Find
    Display the chatbox on defined pages in a variable
    and select Yes
    List of the pages to exclude
    And put this in text area : adv_index ( in CMPS Version 4.0.1 put this : adv_portal )
    Then find [vB4.X.X] List of the templates where the global var is used and put this into text area : adv_portal_shout
    Save this setting
    2) Go to ACP/vBa CMPS/Add Module
    Select [Template Module]
    Fill title field what ever you want
    in Template to include type shout ( you will see this then : adv_portal_shout(you fill this)
    Select your desired template
    And Paste this {vb:raw mgc_cb_evo_var} to the Template Content
    Set Use Module Wrapper Template to "No"
    Set your desired Permissions and Save it. Then add this module to your desired page, which i have added to home page.
    It's Finished Enjoy it.
    If you Have any issue please feel free to contact me about it
    Rad
    SoltanWorld
    If you want Vbadvanced Customized main page,PM me
    Sep 2009
    Penzance Cornwall
    49
    Ok, I'll be the first to comment.
    I like this mode thanks but it doesn't show up in the forum home in the vbadvanced module. It shows up on the forum home ok though.
    i told you dear, Vba Module just works on 3x 2x series, for 4x You should use template module
    Sep 2009
    Penzance Cornwall
    49
    I did use a template module
    do you want to show it on Vba index or forumhome ?
    Sep 2009
    Penzance Cornwall
    49
    I already have it on VBa index I would like to show it on forum home in a module. I have tried but it simply does not show up on forum home as a VBa module.
    aha, if you have integrate it, you would have it, did you? or you can use option on "ACP/MGC Chatbox Evo/Display And Position" to show originally on forumhome
    Sep 2009
    Penzance Cornwall
    49
    Quote Originally Posted by radali View Post
    It shows with option on "ACP/MGC Chatbox Evo/Display And Position" to show originally on forumhome.
    But I want to show it in a module on the forum page and not through ACP/MGC CHATBOX. I want to have full control of the position.
    i use Dream's old chatbox just on my VBA and it works fine on 3.7 & 3.8. IMHO its the best chatbox there is.
    The Best Toyota Forum!!
    Nov 2006
    140
    Yeah but this isn't for vb3.7 and 8
    personally it works great for me Radali much thanks!
    And Halfhidden, are you wrapping your whole site around vBA? Cuz I think thats the only way you'll get the "vba module" to show up in the forumhome.
    Rolla, i would try football ) due to your vote
    TeknoSounds You're welcome dear,Thanks man yeah , i have said it works on Vba 4 just some attention for other user would be fine.
    May 2010
    It's Work Great Thanx Buddy ...cheers Best solution For VBA 4.x
    thnx dude!
    I have an administrator on my forums that isn't a full admin. How can I give him permissions to see the MGC Chatbox options in the admin CP?
    No offense but if you didn't want our honest votes, then why put it as a poll option??
    Honestly the reason I voted that way was because I had installed this, and it seriously loaded down my server causing my site to be slow. Had to un-install it. I use the Dion Dev Shoutbox, but honestly it slows it down too, just not as much.
    Nov 2006
    140
    Well that has nothing to do with his module and everything to do with shoutboxes. I had a similar issue when I was on a shared server...any time it was enabled I got internal server errrors often cuz my host was killing processes.
    Anyway, not the module's fault, its the addon/mod of the shoutbox itself.
    Quote Originally Posted by mdelcour2000 View Post
    oh man i'm not sad that you vote like this, it's your idea! and i'm happy that you are honest with me to share ur ideas, and some votes won't change the fact of people thinking dear, as i use this shout box myself i try to use it as beta one for my web site, and i try to get Vbshout 5 which made by Inferno Shout developers worked on Vba and i hope the bugs which vba has with it, would be solved.
    Thanks Dear
    Feb 2009
    14
    I'm having issues with this. I'm using a fresh install of Vbulletin and I followed the directions above (several times) and I still keep getting vba page without the module. Permissions are set and I tried adding it to the left, right and center blocks as well.
    are you sure you have set the template correctly ?
    IF you can plz let me check it for you! Link me with an account i will set it for you
    Feb 2009
    14
    PM sent.
  1. How do I add the VSA Chatbox to the portal?
    By knight319 in forum "How Do I..." Questions
    Last Post: 10-31-2014, 12:37 AM
  2. Cyb Chatbox into a module
    By haggles in forum "How Do I..." Questions
    Last Post: 12-29-2011, 02:17 PM
  3. Add cyb Chatbox?
    By SpottySocks in forum Module & Modification Discussion & Requests
    Last Post: 12-29-2011, 02:16 PM
  4. MGC Chatbox evo 1.0.0
    By Joachim in forum Module & Modification Discussion & Requests
    Last Post: 07-18-2009, 09:58 AM
