Results 1 to 5 of 5
Thread: Invalid SQL Durning Install
    Default Invalid SQL Durning Install
    Database error in vBulletin 3.8.5:
    INSERT INTO product
    (productid, title, description, version, active)
    VALUES (
    'adv_links',
    'vBadvanced Links Directory',
    '3.3.0',
    1,
    'http://www.vbadvanced.com'
    MySQL Error : Column count doesn't match value count at row 1
    Error Number : 1136
    CREATE TABLE adv_links (
    linkid int(11) NOT NULL auto_increment,
    `name` varchar(255) NOT NULL default '',
    linkurl text NOT NULL,
    linkrecipurl text NOT NULL,
    catid smallint(5) unsigned NOT NULL default '0',
    description text NOT NULL,
    keywords varchar(255) default NULL,
    views int(10) NOT NULL default '0',
    posts int(10) unsigned NOT NULL default '0',
    valid smallint(5) NOT NULL default '0',
    `open` smallint(3) unsigned NOT NULL default '0',
    notes varchar(255) NOT NULL default '',
    sticky smallint(3) unsigned NOT NULL default '0',
    hasthumb varchar(20) NOT NULL,
    username varchar(50) default NULL,
    dateline int(10) unsigned NOT NULL default '0',
    lastupdated int(10) unsigned NOT NULL default '0',
    userid int(10) unsigned NOT NULL default '0',
    votenum smallint(5) unsigned NOT NULL default '0',
    votetotal smallint(5) unsigned NOT NULL default '0',
    ipaddress varchar(15) NOT NULL default '',
    lastpostid int(10) unsigned NOT NULL default '0',
    lastpostdateline int(10) unsigned NOT NULL default '0',
    lastpostuserid int(10) unsigned NOT NULL default '0',
    lastpostusername varchar(255) default NULL,
    PRIMARY KEY (linkid),
    KEY catid (catid,valid,dateline),
    KEY lastupdated (lastupdated),
    FULLTEXT KEY `name` (`name`),
    FULLTEXT KEY description (description),
    FULLTEXT KEY keywords (keywords)
    ) TYPE=MyISAM;
    MySQL Error : Table 'adv_links' already exists
    Error Number : 1050
    Thank you for pointing this out. It looks like there was a small error in the forum/admincp/vbalinks_install.php file that could cause that error with a new install, though I've just updated that file in the download package here to include the fix. If you will download the files from here again, upload that one to your server over the existing file, run the 'Uninstall' option from the admincp/vbalinks_install.php file, and then you should be able to reinstall afterward.
    Yes Sir..
    It worked. Thank you for all your hard work!
  1. Invalid URL
    By HenrikHansen in forum Troubleshooting & Problems
    Last Post: 02-28-2008, 01:37 PM
  2. Invalid - invalid URL error?
    By Planet vB in forum Troubleshooting & Problems
    Last Post: 11-28-2007, 11:47 AM
  3. Some Invalid SQL
    By joggele in forum Troubleshooting & Problems
    Last Post: 10-25-2006, 12:20 PM
  4. Invalid SQL
    By SLGR in forum Troubleshooting & Problems
    Last Post: 04-07-2006, 12:46 AM
