Results 1 to 20 of 34
Thread: Make vba modules look like vb widgets
    Feb 2008
    296
    Default Make vba modules look like vb widgets
    If you are like me and believe vbCMS is only good as an Article section but want to standardise your site making CMPS modules look like vbCMS Widgets then this is how I did it.
    UPDATES
    11th June 2010 - include fix for collapse module function
    4th Dec 2010 - Step 3 code changed to make it W3 Standards Compliant
    Step 1: You can bypass this step if you do not want to use the default module style for any other modules - I still use it for the center column modules.
    - Create a new template called adv_portal_module_wrapper_old
    - Copy your current adv_portal_module_wrapper template into this and save
    (this is the module wrapper template that you will use for default style modules)
    Step 2: Add the following to your additional.css template
    /* VBA CMPS WIDGETS */
    .vba_widget {
        _padding:0;
        overflow: hidden;
        display:vba_block;
        width: 100%;
        clear:both;
        background-color:#f1f1f1;
        border:1px solid #C4C4C4;
        -moz-border-radius:5px;
        -webkit-border-radius: 5px;
        -moz-box-shadow:-2px 2px 2px #C8C8C8;
    .vba_block {
        _margin-bottom:4px;
        padding:6px;
        background:transparent url(../forums/images/misc/blog/top-highlight.png) repeat-x left top;
        -moz-border-radius-topleft:5px;
        -moz-border-radius-topright:5px;
        -webkit-border-top-left-radius: 5px;
        -webkit-border-top-right-radius: 5px;
    .vba_widget_header h3 {
        color: #424242;
        background:transparent none;
        padding: 0px 6px 2px 6px;
        border:none;
        outline:none;
        font: bold 13px Tahoma,Calibri,Verdana,Geneva,sans-serif;
    .vba_widget_content {
        color: #424242;
        border:1px solid #DADADA;
        border-top:1px solid #FFFFFF;
        background:#FFFFFF url(../forums/images/misc/blog/gradient-black-down.png) repeat-x 0 0;
        _background-image: none;
        padding:0px;
    Step 3: Replace everything in your adv_portal_module_wrapper template with this
    {vb:raw mods.formcode}
    <div class="vba_widget">
        <div class="vba_block">
            <div class="vba_widget_header">
                <vb:if condition="$vba_style['portal_collapsemods']">
                    <a class="collapse" id="collapse_module{vb:raw mods.collapse}" style="position: static" href="{vb:raw relpath}#top"><img src="{vb:stylevar imgdir_button}/collapse_40b.png" alt="" border="0" /></a>
                <h3>
                    {vb:raw vba_style.portal_blockbullet} <vb:if condition="$mods['link']"><a href="{vb:raw mods.link}">{vb:raw mods.title}</a><vb:else />{vb:raw mods.title}</vb:if>
                </h3>
            <div class="vba_widget_content" id="module{vb:raw mods.collapse}"<vb:if condition="($mods['useshell'] & $vba_shellint['collapse'])"> style="display: none"</vb:if>>
                <vb:if condition="$show['table']">
                    <table align="center" border="0" cellpadding="0" cellspacing="0" class="blockrow" width="100%">
                        {vb:raw modulehtml}
                <vb:else />
                    <vb:if condition="$show['divrow']">
                        <div class="blockrow">
                            {vb:raw modulehtml}
                    <vb:else />
                        {vb:raw modulehtml}
    <vb:if condition="$show['endform']"></form></vb:if>
    <br />
    This is what I ended up with:
    Attachment 5864
    Hope this helps someone
    Great !
    If you want Vbadvanced Customized main page,PM me
    Awesome!! This is just what I was wanting!
    Jan 2010
    Nice work
    Dec 2004
    Looks good, but you can't collapse the modules. I don't mind though! Thank you.
    Jun 2009
    6
    http://www.nextgenerationgamers.co.uk
    I have applied the changes above but it does not look to good maybe due to the colouring
    I am new to vb and any help with making the change to suit wwould be great
    Many thanks in advance
    cheers
    Feb 2008
    296
    Quote Originally Posted by betts02 View Post
    cheers
    Do you just have vb forums and not the extra vb products of blogs and CMS - it looks like the images are not showing so I guess you don't have them.
    The two images you need are referenced in the code and would be located in the images/misc/blog folder and I am guessing that I legally wouldn't be allowed to attach those images as they would belong to vb
    Feb 2008
    296
    Can anyone help with figuring out a way to make the collapse work properly?
    Jun 2009
    Quote Originally Posted by caitian View Post
    This would be good.
    In the template code supplied, the images are being referenced in a /forum/ folder... anyone that has their forums in a different folder will need to update those 2 spots in the template code given (and need to have the blogs installed
    Great work though, thanks!
    Feb 2008
    296
    Note: The opening post has been updated to include the fix for the collapse module function
    May 2004
    101
    This is fantastic... thank you very much!
    Since I tried to install this it messed with my virgin VBA install. It has made it so that the images I put into modules are all padded on the right bu quite a lot. Also when I first set this up, the modules simply showed white borders and not the color that I have got setup.
    Does anyone know why the modules with images now pad on the right, I have removed this code yet the proble still exists.
    Jun 2010
    This is great sir, perfect! Like the CMS, with nothing to envy. Thank you very much for giving us all and free.
    We expect some further changes and some widgets or modules. Thanks!!
    great
    thnx million it's really nice
    Oct 2009
    Brilliant! Much appreciated.
    Feb 2008
    296
    My pleasure mate
    Note: I am dumping vb and are in the process of moving all my sites over to Xenforo so as soon as Brian releases CMPS, Dynamics and Links for Xenforo I hope to start contributing as many enhancements as I can for that great combination of forum software.
    Example: http://www.recreationalflying.co.nz
    Oct 2009
    Great mod, many thanks.
    BTW How can I make them appear with drop shadows?
    Aug 2004
    23
    thanks, works great !
    Jul 2010
    Chicago, IL
    This looks great. Thanks for doing this. I will be working this very soon.
  1. widgets
    By ttnb in forum Module & Modification Discussion & Requests
    Last Post: 08-22-2011, 06:25 AM
  2. widgets
    By ozidoggy in forum Modifications
    Last Post: 10-01-2010, 02:54 PM
  3. Widgets on vbadvance page
    By wmlvb in forum Module & Modification Discussion & Requests
    Last Post: 09-13-2008, 11:00 AM
  4. How can I create module to show these widgets?
    By GentleOceanWind in forum "How Do I..." Questions
    Last Post: 04-30-2008, 12:06 PM
  5. weather and fox nfl widgets
    By StuntFactoryX in forum Add-On Modules (version 3.x & 2.x)
    Last Post: 12-12-2007, 02:16 AM
